NSCA Network server accept failure (9: Bad file descriptor)
dhineshkumar
Post by dhineshkumar »
Hi.,
I am seeing the following error for NSCA in system logs. After restarting the NSCA services, this error stops coming for a while. When this error is coming the passive checks are not accepted in the Nagios.
nsca[20579]: Network server accept failure (9: Bad file descriptor)
NSCA Server version is 2.9.1.
NSCA Client Version 2.9.1
Can help me to stop this error coming.
Thanks in Advance.
Re: NSCA Network server accept failure (9: Bad file descript
I did some searching and found that this was a bug that was fixed in an earlier version on NSCA.
But another thing that could cause it is too many connections or dropped connections to the server leaving the NSCA daemon stuck and not shutting down.
Can you check and see if that is happening?
Can you login to the server, run the following and post the output?
ps -ef
ulimit -a
You can try and add these 2 lines to your /etc/xinetd.d/nsca file to give it unlimited connections and instances.
per_source      = UNLIMITED
instances       = UNLIMITED
But, if the connections never drop, you may want to fix that instead of doing the edits.
dhineshkumar
Thanks for your reply tgriep.
Nsca is running as standlone and not under xinetd. I could not see any connection dropping in the Nagios server.
Attached the output of the ps -ef and ulimit -a command ouput.
Thanks.
ps output.txt
Output of Command ps -ef
(25.08 KiB) Downloaded 481 times
ulimit.txt
Output of Command Ulimit -a
(696 Bytes) Downloaded 507 times
Without more detailed messages, it is hard to debug.
You could enable debugging in the NSCA daemon by setting the following option to 1 in the nsca.cfg file
debug=1
Then restart NSCA and wait for the error to happen again.
It could also be the open file limit is set too small.
Currently it is set to 1024 open files, you may want to increase that.
dhineshkumar
After troubleshooting for weeks, found the issue on the MTU setting. MTU set on the server is high than the MTU on Network device, which broke the packets and NSCA couldnot identify those packets.
Post by mcapra »
Thanks for sharing your findings!
Is it alright if we lock this thread and mark the issue as resolved?
dhineshkumar
Yes. We can mark this Thread as Resolved.
Thanks.
