I am monitoring my windows server with check_nrpe.
I have set threshold warning = 85 and critical = 95
check_nrpe!check_drivesize! "warn=free<15%""crit=free<05%" drive=*
My one drive is 80 % utilized, its not working, kindly suggest
Thank you!
check_drivesize in windows with threshold
Re: check_drivesize in windows with threshold
Can you show us the full input / output of running the check from the command line?
Thank you rkennedy
Command from CCM
check_nrpe!check_drivesize! "warn=free le 10%" "crit=free le 05%"
I have attached screenshot of monitoring command.
Let me know if need anything else.
I want to monitor check_memory and check_cpu with defined thresholds.
Thank you very much!
Command from CCM
Dear,
its getting hot, please assist.
Thank you!
Thank you!
The CCM doesn't help much as it doesn't have all of the information. Please run it over the CLI, similar to this, but with your parameters - ./check_nrpe -H 192.168.5.47 -c check_drivesize -a "warn=free<95%" "crit=free<90%"rkennedy wrote:Can you show us the full input / output of running the check from the command line?
I will need the full input and output, to see exactly what is being returned in the performance data.
Please do not post twice, it does no good except drop you down to the bottom of our dashboard.Naveed wrote:Dear,
Thank you!
Sure sir!
I would not paste twice.
I have tried possibly below commands.
[root@AXmonitor libexec]# ./check_nrpe -H 12.3.4 -c check_drivesize -a "warn=free<95%" "crit=free<90%"
Exception processing request: Request command contained illegal metachars!
[root@AXmonitor libexec]# ./check_nrpe -H 1.2.3.4 -c check_drivesize -a 'warn=free<95%' 'crit=free<90%'
[root@AXmonitor libexec]# ./check_nrpe -H 1.2.3.4 -c check_drivesize -a 'warn=free\<95%' 'crit=free\<90%'
Kindly suggest.
Thank you!
Kindly suggest.
Thank you!
You need to allow nasty characters, take a look at your NSClient++ configuration and add 'allow nasty characters=true' in both of the sections below. If you have it turned off, make sure to replace it.
[/settings/NRPE/server]
[/settings/external scripts]
Thank you I have enabled both commands in nsclient file after that its working fine now.
My disk utilization is 91%
[root@AXmonitor libexec]# ./check_nrpe -H 1.2.3.4 -c check_drivesize -a "warn=free<90%" "crit=free<98%"
CRITICAL C:\: 114.486GB/126.998GB used, D:\: 9.859GB/284.998GB used|'A:\ free'=0B;0;0;0;0 'C:\ free'=12.51238GB;114.29823;124.45808;0;126.99804 'C:\ free %'=9%;90;98;0;100 'D:\ free'=275.13917GB;256.49823;279.29808;0;284.99804 'D:\ free %'=96%;89;97;0;100
[root@AXmonitor libexec]# ./check_nrpe -H 1.2.3.4 -c check_drivesize -a "warn=free<92%" "crit=free<98%"
CRITICAL C:\: 114.486GB/126.998GB used, D:\: 9.859GB/284.998GB used|'A:\ free'=0B;0;0;0;0 'C:\ free'=12.51238GB;116.8382;124.45808;0;126.99804 'C:\ free %'=9%;92;98;0;100 'D:\ free'=275.13917GB;262.1982;279.29808;0;284.99804 'D:\ free %'=96%;91;97;0;100
[root@AXmonitor libexec]# ./check_nrpe -H 1.2.3.4 -c check_drivesize -a "warn=free<92%" "crit=free<90%"
CRITICAL C:\: 114.486GB/126.998GB used|'A:\ free'=0B;0;0;0;0 'C:\ free'=12.51238GB;116.8382;114.29823;0;126.99804 'C:\ free %'=9%;92;90;0;100 'D:\ free'=275.13917GB;262.1982;256.49823;0;284.99804 'D:\ free %'=96%;91;89;0;100
I have changed the thresholds, but result is always Critical.
I have set thresholds as follows:
Warning = 95 %
Critical = 98 %
But still its showing results Critical rather than to be Warning.
Screenshot is attached as well.
Kindly assist
Thank you!
Warning = 95 %
Critical = 98 %
Kindly assist
Thank you!
I wonder if your A drive is causing the issue since it's 0's across the board, could you check each of them manually to see if that's the case?
./check_nrpe -H 192.168.5.47 -c check_drivesize -a "warn=free<90%" "crit=free<98%" "drive=c"
Thank you for your support!
I have tried your suggested way, but still its not working.
Even I changed drive = d which is only 20 % utilized but due to C drive its showing critical result.
Kindly assist!
Thank you!
Kindly assist!
Thank you!
