This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
robert.anderko
Posts: 33 Joined: Thu Apr 24, 2014 5:38 pm
Post
by robert.anderko » Thu Jun 23, 2016 6:03 am
Hi guys,
i trying get errors from application log in Windows server. When i try:
/usr/local/nagios/libexec/check_nrpe -H ru-aur-p-602 -c CheckEventLog -a file=application MaxWarn=1 MaxCrit=1 "filter=generated > -1d AND level = 'error'"
i get:
Test(error, 6005, success)[test, ], MSSQL$RU_AUR_P_602(error, 6005, success)[test, ], MSSQL$RU_AUR_P_607(error, 6005, success)[test, ], eventlog: 3 > critical|'eventlog'=3;1;1
but with command:
/usr/local/nagios/libexec/check_nrpe -H ru-aur-p-602 -c CheckEventLog -a file=application MaxWarn=1 MaxCrit=1 "filter=generated > -1d AND source='MSSQL$RU_AUR_P_607'"
i get
Eventlog check ok|'eventlog'=0;1;1
Any idea how can i get errors for logsource MSSQL$RU_AUR_P_602 ? and with another check only for MSSQL$RU_AUR_P_607 ?
thx for help
ssax
Dreams In Code
Posts: 7682 Joined: Wed Feb 11, 2015 12:54 pm
Post
by ssax » Thu Jun 23, 2016 1:01 pm
Try it with this:
/usr/local/nagios/libexec/check_nrpe -H ru-aur-p-602 -c CheckEventLog -a file=application MaxWarn=1 MaxCrit=1 'filter=generated > -1d AND source=\'MSSQL$RU_AUR_P_607\''
And this:
/usr/local/nagios/libexec/check_nrpe -H ru-aur-p-602 -c CheckEventLog -a file=application MaxWarn=1 MaxCrit=1 'filter=generated > -1d AND source=\'MSSQL\$RU_AUR_P_607\''
Or this:
/usr/local/nagios/libexec/check_nrpe -H ru-aur-p-602 -c CheckEventLog -a file=application MaxWarn=1 MaxCrit=1 "filter=generated > -1d AND source='MSSQL\$RU_AUR_P_607'"
Let us know the results.
Thank you
robert.anderko
Post
by robert.anderko » Fri Jun 24, 2016 9:34 pm
Hi ssax,
last example seems work OK. thx for reply & for usefull help. This thread can be locked.
robert.anderko
Post
by robert.anderko » Mon Jun 27, 2016 1:44 am
hi guys,
maybe, i have question - from bash, is all ok:
/usr/local/nagios/libexec/check_nrpe -H host -c CheckEventLog -a file=application MaxWarn=1 MaxCrit=1 "filter=generated > -5m AND source='MSSQL\$RU_AUR_P_601' AND lev
But from, GUI:
COMMAND: /usr/local/nagios/libexec/check_nrpe -H host -t 60 -c CheckEventLog -a file=application MaxWarn=1 MaxCrit=1 "filter=generated \> -5m AND source=\'MSSQL\\\$RU_AUR_P_601\' AND level = \'error\'"
OUTPUT: Parsing failed: generated \> -5m AND source=\'MSSQL\$RU_AUR_P_601\' AND level = \'error\'
any idea?
thx
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Mon Jun 27, 2016 1:48 am
Due to some issues with how PHP escapes characters the "Test Check Command" does not work in these situations and should be ignored.
So for all further testing of this service you need to:
Make the changes to the service
Save the Service
Apply Configuration
Go back to the home screen and find the Service
When viewing the Service Status Details page click the Schedule a forced immediate check link
Just to re-iterate, for all further testing for this service DO NOT use the "Test Check Command" button, follow the steps above.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
robert.anderko
Post
by robert.anderko » Mon Jun 27, 2016 2:44 am
Box239,
all works! thx for fast reply and for interesting manual.
Post
by Box293 » Mon Jun 27, 2016 2:45 am
Excellent, glad to help you get it working.
Privacy Policy .
