how can play an alarm or bib with warning or critical
dear all
Hi
i want to know how can set alarm for nagios means when a service or host appear with warning or critical play a bib or alarm ?
Best regards
Babak
Hi
Best regards
Babak
Re: how can play an alarm or bib with warning or critical
What machine are you trying to play a sound on? With the Nagios server, you should just be able to create a command that plays a sound on the local machine.
i just want when any warning or critical appear in nagios alam or horn playrkennedy wrote:What machine are you trying to play a sound on? With the Nagios server, you should just be able to create a command that plays a sound on the local machine.
where do i have to config that ?
Again, we need to know what machine should play the sound. The implementation is going to be different depending on whether you want the sound to come from your browser, or from the server that hosts Nagios.
If you want this played on the Nagios server: http://askubuntu.com/questions/83200/ho ... ifications
Otherwise from your browser: https://assets.nagios.com/downloads/nag ... dio_alerts
doing this with nagvis is perhaps the easiest way to do it
default action for nagvis is to play an annoying noise whenever anything on the map turns red
Take a look at the options @mcdonald mentioned, and @nozlaf as well - let us know if you have any further questions about it.
tmcdonald wrote:Again, we need to know what machine should play the sound. The implementation is going to be different depending on whether you want the sound to come from your browser, or from the server that hosts Nagios.
excusem i have read audio from browser but realy could not understand that means which file do i have to edit?
can you giva me an example for example if appear a warning about memory appear in my nagios i want play alarm realy confused what do i have to edit that work for all services and hosts ?
You'll want to make the change to your cgi.cfg -
Formats: host_unreachable_sound=<sound_file>
host_down_sound=<sound_file>
service_critical_sound=<sound_file>
service_warning_sound=<sound_file>
service_unknown_sound=<sound_file>
Examples: host_unreachable_sound=hostu.wav
host_down_sound=hostd.wav
service_critical_sound=critical.wav
service_warning_sound=warning.wav
service_unknown_sound=unknown.wav
i have added this code in the end of my cgi.cfg file but nothing do i am using mozilla firefox 43.0.1 and attached cgi.cfg filerkennedy wrote:You'll want to make the change to your cgi.cfg -Code: Select all
Formats: host_unreachable_sound=<sound_file> host_down_sound=<sound_file> service_critical_sound=<sound_file> service_warning_sound=<sound_file> service_unknown_sound=<sound_file> Examples: host_unreachable_sound=hostu.wav host_down_sound=hostd.wav service_critical_sound=critical.wav service_warning_sound=warning.wav service_unknown_sound=unknown.wav
So thanks
I have to copy and paste exactly that code in the end of cgi.cfg file?
Instead of warning.wav what do i have to write ?? Path of warning.wav file ? How can wrie?
Warm regards
cgi.cfg- (12.33 KiB) Downloaded 528 times
According to the Nagios Core documentation:
to this:
Restart nagios and apache. Let us know if you have any more questions.
You will need to place the audio files (hostu.wav, hostd.wav, critical.wav, warning.wav, and unknown.wav) in the "/usr/local/nagios/share/media" directory. Next, you will need to modify the cgi.cfg file by changing this:Audio files are assumed to be in the media/ subdirectory in your HTML directory (i.e. /usr/local/nagios/share/media).
service_unknown_sound=unknown.wavCode: Select all
service_unknown_sound=unknown.wavBe sure to check out our Knowledgebase for helpful articles and solutions!
