Hello LOG server support
We have followed Update manual from https://library.nagios.com/library/prod ... structions and received "Upgrade Complete" message.
However before and after reboot LOG server still shows version 1.4.0 instead of 1.4.1
Please help with this issue
Thank you
LOG server still shows previous version after an update
Re: LOG server still shows previous version after an update
If you're talking about the version that shows at the bottom, the check is not dynamic. It only updates once a day. Check for updates again, that will tell you for certain what version you have.
OKeloyd wrote:If you're talking about the version that shows at the bottom, the check is not dynamic. It only updates once a day. Check for updates again, that will tell you for certain what version you have.
Thank you
Please close
