Alerting if host not using at least certain CPU and memory
robert.anderko
Post by robert.anderko »
I am using Nagios XI 5.2.9. I am needing to find a way to alert if hosts across my infrastructure are not being fully utilized. Looking for something like if host check has not seen at least 50% CPU or memory in 7 days/last month then alert staff to look at adjustments.
Thanks in advance.
Re: Alerting if host not using at least certain CPU and memo
Alerting based on a time range can either be done at the plugin level, or if the plugin does not support this you can do it using an open-source project called Bischeck:
Basically you can define averages, minimums, and maximums for the last X number of checks. This doc only goes into averages, but the linked Bischeck references should help with any additional usage issues you run into.
