im using check_nt to Monitor if a Windows Service is down.
Is it possible to use check_nt if a sevice is running.
E. g. that if the Service is running a critical alert is generated?
Dennis
check_nt
Re: check_nt
Check out this page: https://assets.nagios.com/downloads/nag ... ndows.html
host_name winserver
service_description W3SVC
check_command check_nt!SERVICESTATE!-d SHOWALL -l W3SVC
}Former Nagios Employee.
me.
me.
Re: check_nt
Ok. But this Generates a critical alert of Service is stopped.
I want to generate an alert of Service is Started.
Re: check_nt
You need Negate! Check that document out. The document is for Core, but the same ideas still apply for XI.
me.
me.
