i'm trying to install linux REHL 4 nagios client on my Linux servers and i have these errors messages ...someone could help me please ?
Do you want to continue? [Y/n] Y
Proceeding with installation...
Current step is 1-prereqs
Installing prerequisites...
Fetching Obsoletes list for channel: rhel-x86_64-as-4...
Fetching rpm headers...
Error in sys.excepthook:
Traceback (most recent call last):
File "/usr/sbin/up2date", line 1280, in exceptionHandler
print _("An error has occurred:")
IOError: [Errno 32] Broken pipe
Original exception was:
File "/usr/sbin/up2date", line 1312, in ?
sys.exit(main() or 0)
File "/usr/sbin/up2date", line 813, in main
fullUpdate, dryRun=options.dry_run))
File "/usr/sbin/up2date", line 1143, in batchRun
batch.init()
File "/usr/share/rhn/up2date_client/up2dateBatch.py", line 71, in init
self.__findPackagesToUpdate()
File "/usr/share/rhn/up2date_client/up2dateBatch.py", line 118, in __findPacka
gesToUpdate
self.availableUpdates = plist.getPackagesToInstall()
File "/usr/share/rhn/up2date_client/packageList.py", line 691, in getPackagesT
oInstall
result = self.__skipPackages(result)
File "/usr/share/rhn/up2date_client/packageList.py", line 720, in __skipPackag
es
packageList = self.__skipFiles(packageList)
File "/usr/share/rhn/up2date_client/packageList.py", line 741, in __skipFiles
ignoreMsgCallback = self.ignoreMsgCallback)
File "/usr/share/rhn/up2date_client/packageList.py", line 786, in buildHeaderL
ist
hdr = headerList[pkg]
File "/usr/share/rhn/up2date_client/headers.py", line 37, in __getitem__
self.__retrievePackage(item)
File "/usr/share/rhn/up2date_client/headers.py", line 42, in __retrievePackage
hdr, sourceType = rpcServer.doCall(self.repos.getHeader, item)
File "/usr/share/rhn/up2date_client/rpcServer.py", line 238, in doCall
ret = apply(method, args, kwargs)
File "/usr/share/rhn/up2date_client/repoDirector.py", line 33, in getHeader
return self.handlers[channel['type']].getHeader(pkg, msgCallback, progressCa
llback)
File "/usr/share/rhn/up2date_client/rpmSource.py", line 213, in getHeader
header = source.getHeader(pkg, progressCallback = progressCallback)
File "/usr/share/rhn/up2date_client/repoBackends/up2dateRepo.py", line 154, in
getHeader
fd = self.s.getPackageHeader(channel, filename)
File "/usr/lib/python2.3/site-packages/rhn/rpclib.py", line 622, in __call__
result = self._send(self._name, args)
File "/usr/lib/python2.3/site-packages/rhn/rpclib.py", line 319, in _request
request, verbose=self._verbose)
File "/usr/lib/python2.3/site-packages/rhn/transports.py", line 172, in reques
t
headers, fd = req.send_http(host, handler)
File "/usr/lib/python2.3/site-packages/rhn/transports.py", line 704, in send_h
ttp
response = self._connection.getresponse()
File "/usr/lib/python2.3/site-packages/rhn/connections.py", line 143, in getre
sponse
response.begin()
File "/usr/lib64/python2.3/httplib.py", line 273, in begin
version, status, reason = self._read_status()
File "/usr/lib64/python2.3/httplib.py", line 231, in _read_status
line = self.fp.readline()
File "/usr/lib/python2.3/site-packages/rhn/SSL.py", line 272, in readline
self._poll(select.POLLIN, 'readline')
File "/usr/lib/python2.3/site-packages/rhn/SSL.py", line 201, in _poll
res = poller.poll(self._sock.gettimeout() * 1000)
select.error: (4, 'Interrupted system call')
Installation step failed - exiting. Check for error messages.
