Change the ip addresses of NLS cluster
bennspectrum
Post by bennspectrum »
Hello team,
I have a problem here. In the beginning, I installed the 2 nodes NLS cluster, and the ip address were 192.168.0.47 and 192.168.0.48, respectively. Afterwards, I changed the ip addresses to 192.168.0.118 and 192.168.0.119, respectively. Set up the /usr/local/nagioslogserver/var/cluster_hosts to 192.168.0.118, 192.168.0.119.
I thought everything is OK, but when I input
curl 'localhost:9200/_cat/master?v'
It's seem to like NLS still consider the master is 192.168.0.48. What's should I do?
By the way, I want to backup my log data but it not working. I guess maybe I solve the problem above the backup function do work normally. Thanks.
Re: Change the ip addresses of NLS cluster
Just to make sure we're on the same page, could you provide the exact steps you've followed so far? Please post a copy of your /etc/hosts file as it will help as well to see if something is stuck in DNS.
bennspectrum
Thanks to your reply, rkennedy.
The steps are shown as following,
1. I installed the 2 nodes NLS cluster on two CentOS machines, and the dhcp ip adrdess of the two CentOS machines are 192.168.0.47 and 192.168.0.48, respectively.
2. I changed the two ip addresses to 192.168.0.118 and 192.168.0.119, and restart the NLS cluster.
3. I found that the two nodes of the NLS cluster could not find each other, so I search the solve method on nagios forum and found out the way below.
https://support.nagios.com/forum/viewto ... er#p185409
the output of
cat /usr/local/nagioslogserver/var/cluster_hosts
4. I set up the cluster_hosts file and the NLS cluster nodes could find each other. I considered that it was success, but when I input
, the output show the master node ip is 192.168.0.48.
Could someone tell me what configuration do I omission?
hsmith
Agent Smith
Post by hsmith »
Can you tell me what 'interface URL' says under Administration > General > Global Settings? Also, under Instance Status in the Global Configuration menu can you make sure the IPs are correct?
Former Nagios Employee.
me.
bennspectrum
Thank you!!! hsmith
I change it to http://192.168.0.118, origin is http://192.168.0.47
Now, it become 127.0.0.1, Is it normal?
hsmith
Agent Smith
Post by hsmith »
Not the same thing I see on mine. Is it showing on both nodes as 127.0.0.1 ?
me.
bennspectrum
To hsmith,
Yes, both nodes are 127.0.0.1.
hsmith
Agent Smith
Post by hsmith »
If both nodes think they are the master, you might have a problem. Can I see the output of the previous command on both nodes?
me.
bennspectrum
Thank you hsmith,
I am sorry, I already removed them and reinstalled one.
Post by mcapra »
Were you able to solve your problem? Is it alright if we lock this thread and mark the issue as resolved?
