I have two web servers (serverA and serverB) behind a load balanced address serverLB. If you try to connect to the individual servers by hostname you get redirected. One page only (for monitoring) is accesible directly via IP address on each web server.
From the command line I can run the command:
./check_http -I 10.10.8.64 -f follow -s "Results check:" or ./check_http -I 10.10.8.65 -f follow -s "Results check:"So I've assumed that if I set this in my services.cfg file, everything would be OK.
use generic-service ; Name of service template to use
host_name serverA
service_description Homepage
check_command check_http! -I 10.10.8.64 -f follow -s "Results check:"
host_name serverB
check_command check_http! -I 10.10.8.65 -f follow -s "Results check:"
}This looks like a bug to me, unless someone can tell me otherwise?
