Hi team,
We are monitoring MSSQL Database.One of the requirement to monitor if a MSSQL database goes into suspect mode.Can anyone help me with this
MSSQL Database in Suspect mode
gselvakumar
Thanks & Regards,
Gomathyshankar Selvakumar
- Box293
- Too Basu
Re: MSSQL Database in Suspect mode
I can't find anything on the Nagios exchange for this.
How do you detect if a database is in suspect mode? Is there a query you can perform?
nietonoshana
Yes, The Status in database is located in sys.databasesBox293 wrote:I can't find anything on the Nagios exchange for this.
Can you use Wizard MSSQL Query and put there:
SELECT count( state_desc) FROM master.sys.databases where state_desc like 'SUSPECT'Or you can add a filter by the name of the base
SELECT count( state_desc) FROM master.sys.databases where state_desc like 'SUSPECT' and name like 'databasename' - Box293
- Too Basu
Excellent, those queries can be used with the wizard.
Run the MSSQL Query Wizard.
You will be able to add the query on Step 2 of the wizard.
Does this help?
Does this help?
gselvakumar
sorry for the delay in response
Thanks nietoshana and Box293.The above mentioned query is working.
Thanks & Regards,
Awesome! Are we good to mark this one as resolved?
gselvakumar
Yes .Once again thanks
Thanks & Regards,
