NAGIOSQL error when creating new service
nuggi
Post by nuggi »
This problem occured after i deleted every single service inside NAGIOSQL Supervision. I was testing something and decided to start from scratch when i discovered that deleting all services apparently broke something. Now when i'm trying to create a new service inside NagiosQL i get the following error: "Error while inserting the data into the database
:Field 'import_hash' doesn't have a default value" I know this has something to do with the SQL query, but i have no idea what to do with this error, and sadly hours of google searching provided no answers for my case. Do i have to start over again, or is there any easy way to fix this error?
Re: NAGIOSQL error when creating new service
Post by Box293 »
It's probably easier to re-install Nagios QL, or at least re-create the database.
Perhaps run up another server and install NagiosQL on it and then backup the database and restore it on your original server.
nuggi
Post by nuggi »
Whats the easiest way to recreate the database?
nuggi wrote:Whats the easiest way to recreate the database?
It's what @Box293 mentioned -
This would preserve the structure of QL, and allow you to then dump it on the new server and import the SQL dump to your old server.
