switch case available in logstash?
_asp_
Post by _asp_ »
is "switch case" function available in logstash? I didn't find it in documentation, but maybe i just looked at the wrong place.
Thanks, Andreas
hsmith
Agent Smith
Re: switch case available in logstash?
Post by hsmith »
Can you please provide some context as to exactly what you're trying to do?
Former Nagios Employee.
me.
_asp_
Post by _asp_ »
I have a field named status which contains a status as number which I extract from the logs.
Following status mapping as example: statuscode=codenumber -> statusCluster
0=pending -> pending
1=authenticating -> auth
2=processing ->
10 - 20 =different error codes
30=user cancel -> cancelByUser
To be able to use the status with comfort I would like to cluster it to a new field which is named statusCluster:
my target would be:
switch (status)
    case 30:
        mutate
		add_field => { "StatusCluster" => "cancelByUser" }
        break;
   case 0:
      mutate
		add_field => { "StatusCluster" => "pending" }
        break;
       ... and so on ...
but without switch case I need to do it with nested if statements which I am currently using.
But switch case - if existing - would simplify the code
Post by mcapra »
It does not look like Logstash supports switch conditionals, though I agree this would provide a route for cleaner code.
https://www.elastic.co/guide/en/logstas ... ation.html
I would suggest raising an issue on logstash the github page if this is a feature you would like to see implemented:
https://github.com/elastic/logstash
