Exporting config
tonyyarusso
Exporting config
Post by tonyyarusso »
There is a document available on "Exporting the XI Configuration Database", at http://bit.ly/dgSQLm
From the description,
"This guide takes you through the process of manually exporting the Nagios XI configuration database and checking for errors that need resolution. Manual exports are useful when debugging configuration errors - including the failure of XI to apply a new configuration when using the wizard or the Nagios Core Config Manager."
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
