Clone Existing Nagiosxi setup.
lntinfo
Post by lntinfo »
i have existing nagiosxi server setup and running completely ok.now i have another linux slice with same configuration and same arch. but due to security reason i am not having internet access on new linux slice, for enable internet access, we need approval and all that stuff will take another weeek. is therer any way i can clone my existing linux slice with nagiosxi with new one.
or anything like i can installed nagiosxi without internet is that possible?
mguthrie
Re: Clone Existing Nagiosxi setup.
Post by mguthrie »
Can you try the backup-restore procedure onto the second system? Or else migrate your configs by using the import tool to the clone?
http://assets.nagios.com/downloads/nagi ... kuprestore
http://assets.nagios.com/downloads/nagi ... ngfromcore
lntinfo
Post by lntinfo »
thnx for reply..
back and restore wont work here becasue for restoring backup on new machine again i need to have installed nagiosxi on new machine.then only i can able to run restore script.
problem is resolve. i have clone my existing nagiosxi server with new one.
thnx a ton....
