Unable to run check on non-child node. Revise your query
jcwuerfl
Post by jcwuerfl »
Why doesn't this produce an alert of some kind ?
COMMAND: /usr/local/nagios/libexec/check_ncpa.py -H hostname.domain.com -t 'password' -P 5693 -M 'disk/logical/\|dbdata/used_percent' -w 90 -c 95
OUTPUT: Unable to run check on non-child node. Revise your query.
Re: Unable to run check on non-child node. Revise your query
It is because the check is configured properly - only testing (from within CCM) fails. The "error" output is caused by escaping issues.
So, instead of running this:
try running this from the command line:
/usr/local/nagios/libexec/check_ncpa.py -H hostname.domain.com -t 'password' -P 5693 -M 'disk/logical/|dbdata/used_percent' -w 90 -c 95
(remove the "\" in front of the pipe).
jcwuerfl
Post by jcwuerfl »
Currently I have /dbdata unmounted.
This :
Gives me :
File returned contained:
  "value": {
    "returncode": 0,
    "stdout": "OK: used_percent was 6% | 'used_percent_0'=6%;90;95;"
The below doesn't work and does give me the error, however it gives me the same error with hosts with /dbdata mounted?
error:
  "value": {
    "returncode": 3,
    "stdout": "Unable to run check on non-child node. Revise your query."
jcwuerfl
Post by jcwuerfl »
I still had a directory there w/o the mount being "mounted" there so was still working as it was check the root space as apposed to the /dbdata mount I believe.
Thanks!
bwallace
Post by bwallace »
Thanks for the update - are we good to lock this thread or do you prefer it be left open awhile longer?
