100% CPU usage for one processor for more than 10 minutes
gselvakumar
Post by gselvakumar »
Hi Team,
we are monitoring Cpu stats, memory usage for Linux servers. But there are is requirement that we need to monitor 100% CPU usage for one processor for more than 10 minutes.
Could you suggest the possible solution
Thanks & Regards,
Gomathyshankar Selvakumar
Re: 100% CPU usage for one processor for more than 10 minute
Post by mcapra »
This sounds like something that should be done within the "Check Settings" for the service.
You could set your "Retry Interval" to 2 minutes and your max check attempts to 5. Alternatively, you could set the "Retry Interval" to 1 minute and your max check attempts to 10.
