I have a quite simple problem.
One of our services on a Windows server has two space signs in it, like: "FANCY SERVICE name".
So between SERVICE and name You can notice two spacebars.
Thus the SNMP wizard sees the spaces correctly when I pick the service to be monitored it saves the name with only one.
Correcting the service name gives no effect, after saving the config there is only one space.
How can I escape this weird problem from within Nagios?
Windows SNMP service - two spaces in name
Re: Windows SNMP service - two spaces in name
Can you show us the full check_command that you're currently using with the service? It could just be a matter of adding quotes, or double quotes.
this one is from Nagios XI UI:
check_xi_service_snmp_win_service! -C XXXX --v2c -r -n 'YSoft PostgreSQL embedded database'
Whenever I change it to:
and save it, and then reopen the config, the double space is gone.
I was able to recreate the issue in Nagios XI 5.2.9, however saving a service with two spaces in the name worked just fine in our development revision. So, I won't be posting a bug report as the issue seems to be resolved.
For the time being, you could try to place the service name in the "/usr/local/nagios/etc/resource.cfg" file (use user macros) as a "workaround". For example, in the resource.cfg file, you could have:
(double space between "PostgreSQL" and "embedded")
You service command could be:
For more information on using user macros, please review our documentation on the topic here:
https://assets.nagios.com/downloads/nag ... Macros.pdf
Important: Testing the check from the CCM will probably fail, so just lick on the service under the "Service Detail" page, and schedule a forced immediate check to test it.
Let us know if this helped.
$USER9$=YSoft PostgreSQL embedded databaseYou service command could be:
check_xi_service_snmp_win_service! -C XXXX--v2c -r -n '$USER9$https://assets.nagios.com/downloads/nag ... Macros.pdf
OK, this worked fine, so I should wait for the next update and this issue should be solved?
If Yes then You can close this topic, and thank You
It appears to be fixed in the latest development version. That's not a guarantee that it will be in 5.3.0 (a dev might correct me), but it's incredibly likely.
Closing this up per your request
