I'm trying to get the following check_snmp command to work:
check_snmp!-c mysnmpcommunity -o sysUpTime.0 -t 60
But I'm getting the error of (Service check timed out after 60.05 seconds). In the log I see:
[07-12-2016 19:06:52] wproc: Core Worker 12854: job 0 (pid=12985): Dormant child reaped
[07-12-2016 19:06:52] Warning: Check of service 'Port 1 Link Status' on host 'srw2016' timed out after 60.047s!
[07-12-2016 19:06:52] wproc: early_timeout=1; exited_ok=0; wait_status=0; error_code=62;
[07-12-2016 19:06:52] wproc: host=srw2016; service=Port 1 Link Status;
[07-12-2016 19:06:52] wproc: CHECK job 0 from worker Core Worker 12854 timed out after 60.05s
[07-12-2016 19:06:52] wproc: Core Worker 12854: job 0 (pid=12985) timed out. Killing it
I know it's responding, other snmp network monitoring programs I have ran work fine. I read over the tracker log at http://tracker.nagios.org/view.php?id=529, but I'm running 4.1.1 so I'm not sure where to go from here.
check_snmp timeout issue
- Box293
- Too Basu
Re: check_snmp timeout issue
Can you please post the check_snmp command you have defined in your Nagios config file.
uptime:
check_snmp!-c tpfndsnmp -o sysUpTime.0 -t 60
Port 1:
check_snmp!-c tpfndsnmp -o ifOperStatus.1 -r 1 -m RFC1213-MIB -t60
tpfndsnmp is my community string. I also am running Spiceworks Network Monitor on the switch, so I know the community string works.
Port 1:
- Box293
- Too Basu
what is the command definition for check_snmp ?
command_name check_snmp
command_line xxxxxxx
}As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Did you specify the Hostaddress somewhere?
This does work for me.
Please try to execute the check on the commandline.
#check_snmp 10.10.10.1 -c public -o sysUpTime.0 -t 60
SNMP OK - Timeticks: (3218016033) 372 days, 10:56:00.33 |
Rob Hassing
I got it. I had -c communitystring, it's supposed to be -C communitystring. -c is for "Critical threshold range(s)". Now It's all green!
