I am monitoring my windows machines with check_nrpe, all my services are working fine.
I instantly checked and found that my memory plugin is not making graph although service is running fine.
Please check and let me know what goes wrong due to which graph is not populating.
Thank you!
check_memory graph is not showing
Re: check_memory graph is not showing
Can you show us a screenshot of the 'Advanced' tab? The plugin may not be returning performance data.
What do you want me to provide you?
I could not understand about the Advanced tab
Please explain
Thank you!
Please explain
Thank you!
The tab to the Right of the Performance Graphs for that service is called the Advanced Tab, we need to see a screen shot of that tab to determine if the plugin has performance data.
Also, how long was the check running before looking at the graph? It takes around 15 to 20 minutes to populate with data.
I think I have attached what you are asking for?
If not please let me know I will provide you.
Thank you!
Thank you!
Did that check get changed in late June? If the check was changed and the performance data output is now different, you may have to delete the xml and the rrd files for that host's memory check so they will get recreated.
Those files are located in this folder
Just delete the files for the for that check and they will be recreated with the correct data.
This is the example of the screen shot we need.
/usr/local/nagios/share/perfdata/UATSP01This is the example of the screen shot we need.
Great!
That worked for me...
But for only one service it is giving below error.
No performance graphs were found for this service. If you have just started monitoring this object then it may take up to 15 minutes for the performance graphs to appear.
I have checked its perdata folder but it does not contain .rdd and .xml file.
Thank you!
Thank you!
Can you show us a screenshot for this specific service, that isn't showing performance graphs? If the RRD / XML files aren't there, it may not be generating data.
See the example @tgriep posted, for where the 'Advanced' tab is located. It's right next to the 'Performance Graphs' tab.
After much Rnd from google, I have resolved the issue.
I need to tweak my plugin to generate performance data.
You may close this thread as solved.
Thank you everyone for help!
Closing this per your request
