Hi Team,
I am currently using Nagios XI Version 5R1.0.
Whenever i tried to use renaming tool it causes me so many config files issues which were correct.
It makes me to restore the config snapshot to revive the tool.
Note : Once after the snapshot restored, renamed server data also lost.
Kindly help us to fix the same.
Rgds
Srini
Nagios XI 5R1.0 Renaming tool issue
Re: Nagios XI 5R1.0 Renaming tool issue
Can you describe in details all of the steps you took to rename your host(s)/service(s)? Show us configuration files and screenshots showing the errors that you are getting.
Also, 5R1.0 is a somewhat old. Nagios XI 5.2.9 has been available for download since June 14, 2016... Is there any chance for you to upgrade to the latest? This *may* fix your issue as there is a huge number of bugs that have been fixed since 5R1.0.
