notifications not going out
Having trouble getting any notifications going out .
it seems that when their is a status change the email is not triggering to send even though based on the notifications it should
affecting all users .
Is there a doc I should reference
Re: notifications not going out
This could be many different things.
When you look at the Home -> Notifications page, is it showing as triggered, or does it not show up on this page?
Here's a couple of links to get you started.
https://support.nagios.com/kb/article.php?id=36
Let us know if these documents helped you solve your notification issues.
this is becoming a bit maddening ... I see some notifications in home > notifications but alert mail to the users are going out incorrectly
but test emails are going out correctly
Something is not right and I am having trouble finding what
23E277B4: to=<[email protected]>, orig_to=<$>, relay=local, delay=0.03, delays=0.03/0/0/0, dsn=5.1.1, status=bounced (unknown user: "$")Something is not right and I am having trouble finding what
Can you show us a screenshot of your Admin -> Manage Email Settings page?thenomad wrote:this is becoming a bit maddening ... I see some notifications in home > notifications but alert mail to the users are going out incorrectly
but test emails are going out correctlyCode: Select all
here you go
If you are using SMTP, you need to select the "SMTP" check-box under "Mail Settings" page, and lick on "Update Settings". I will also recommend that you change the "from" address to something other than "root@localhost".
sendmail (postfix) is preferred. We can change the sender ... that's not a problem.
Can you show us all of the relevant configs (host/service in question, contactgroup/contact added to this host/service, contact templates, notification handlers)?
Also, run the following command and show the output in code wraps:
tail -100 /var/log/maillogBe sure to check out our Knowledgebase for helpful articles and solutions!
can someone contact me - my notifications are not even fireing at this point so the mail log is irrelevant
