Table with multiple fields
opene2
Post by opene2 »
We have a log that has IP address as field 1 and browser type as field 2. Is it possible to create a single table with field 1 and field 2 in the dash board?
hsmith
Agent Smith
Re: Table with multiple fields
Post by hsmith »
I'm not aware of a way.
A method you could use to accomplish what you're trying to do is using a mutate filter to make another field with both of the items put together.
Former Nagios Employee.
me.
opene2
Post by opene2 »
Thanks. mutate method worked.
Post by mcapra »
Is it alright if we lock this thread and mark the issue as resolved?
opene2
Post by opene2 »
Yes
