mssql replication
pccwglobalit
mssql replication
Post by pccwglobalit »
How to use nagios xi to check mssql 2012 replication status? can we do that? thanks
Re: mssql replication
Post by Box293 »
The only thing I could find on the Nagios Exchange is this:
https://exchange.nagios.org/directory/P ... ng/details
Otherwise, if you can find the information out using a query then you can use the MSSQL Query wizard.
