export downtime from 3.5.1 to 4.1.1
nagmoto
Post by nagmoto »
Hi
For a Nagios 4 server upgrade poject,
I need to export many host/services downtime in Nagios 3.5.1 into Nagios 4.1.1
Can you provide some guidance on how to do this ?
So far, retentsion.dat rsync between two nodes looks like doing the job on downtime setting carry over.
ie, What status/info can't be copied over by rysnc files ?
PS: This is a active(3.5.1)/active-muted(4.1.1) dual servers setup. 2nd server has alerting disabled. 2nd server
ssax
Dreams In Code
Re: export downtime from 3.5.1 to 4.1.1
Post by ssax »
Are you using ndo2db/ndomod/ndoutils as well (data stored in the DB)? As long as you're not using NDO then it's all flat files and rsync should work.
I can't really recommend just rsyncing the files (not the host/service configs) from 3.5.1 to 4.1.1 though, there have been a lot of changes since 3.5.1 and you will likely run into some issues.
That being said, you should be able to rsync all the host/service configs over and as long as they verify properly it should work.
nagmoto
Post by nagmoto »
Thanks for the reply ssax
no ndoutils enabled on Nagios 3.5.1. but on dest Nagios 4.1.1, ndoutil is enabled to send info to MariaDB.
For my understanding, ndo is an add-on. It convert info in flat files like retention.dat , objects/*.cfg servers/*.cfg into mysql tables.
the direct rsync of retention.dat file from 3.5.1 to 4.1.1 server so far is ok. I am able to see all the downtime/host/server active check disabling got carry over.
Are you saying if ndoutil is enable on 4.1.1, I shouldn't have a retention.dat file ?
Yes. there are some marco definitions no longer applicable for 4.1.1, but I was able/luky to remove those variables from 3.5.1/etc/nagios/objects/*.cfg before rsync over to 4.1.1.
Having NDOUTILS enabled on your system, doesn't take anything away from Nagios Core, you should still have the retention.dat file.
All Ndoutils does is store the information from Nagios in to MYSQL so third party tools can access the data using MYSQL.
Does that answer your question?
nagmoto
Post by nagmoto »
Yes. this is my understanding also. Please resolve this ticket.
