There is a document on "Using The Nagios XI Config Import Prep Tool", available from http://bit.ly/aWI3MB
From the description,
"Nagios XI includes a configuration file import prep tool designed to pre-process native Nagios Core configuration files into a format that will be more easily manageable using the XI web configuration frontend in the future. The import prep tool should be used before importing native Nagios Core configuration files into the Nagios Core Configuration Manager included in Nagios XI. This guide shows you how to how to use the Nagios XI configuration file import prep tool. "
Config import prep tool
tonyyarusso
