YUM update missing dependency
as300182
Post by as300182 »
When running a yum update on a RedHat 5.11 server recently, I was very surprised to see this:
--> Processing Dependency: nagios-plugins = 1.4.15-2.el5 for package: nagios-plugins-load
--> Processing Dependency: nagios-plugins = 1.4.15-2.el5 for package: nagios-plugins-disk
--> Processing Dependency: nagios-plugins = 1.4.15-2.el5 for package: nagios-plugins-procs
---> Package nagios-plugins.x86_64 0:1.4.16-1.el5.rf set to be updated
--> Processing Dependency: fping for package: nagios-plugins
--> Processing Dependency: perl(Net::SNMP) for package: nagios-plugins
--> Running transaction check
---> Package fping.x86_64 0:3.10-1.el5.rf set to be updated
---> Package perl-Net-SNMP.noarch 0:5.2.0-1.2.el5.rf set to be updated
--> Processing Dependency: perl(Socket6) >= 0.19 for package: perl-Net-SNMP
--> Processing Dependency: perl(Digest::HMAC) for package: perl-Net-SNMP
--> Processing Dependency: perl(Crypt::DES) for package: perl-Net-SNMP
--> Processing Dependency: perl(Digest::SHA1) for package: perl-Net-SNMP
---> Package perl-Crypt-DES.x86_64 0:2.05-3.2.el5.rf set to be updated
---> Package perl-Digest-HMAC.noarch 0:1.01-15 set to be updated
---> Package perl-Digest-SHA1.x86_64 0:2.11-1.2.1 set to be updated
---> Package perl-Socket6.x86_64 0:0.19-3.fc6 set to be updated
nagios-plugins-procs-1.4.15-2.el5.x86_64 from installed has depsolving problems
  --> Missing Dependency: nagios-plugins = 1.4.15-2.el5 is needed by package nagios-plugins-procs-1.4.15-2.el5.x86_64 (installed)
nagios-plugins-load-1.4.15-2.el5.x86_64 from installed has depsolving problems
  --> Missing Dependency: nagios-plugins = 1.4.15-2.el5 is needed by package nagios-plugins-load-1.4.15-2.el5.x86_64 (installed)
nagios-plugins-disk-1.4.15-2.el5.x86_64 from installed has depsolving problems
  --> Missing Dependency: nagios-plugins = 1.4.15-2.el5 is needed by package nagios-plugins-disk-1.4.15-2.el5.x86_64 (installed)
Error: Missing Dependency: nagios-plugins = 1.4.15-2.el5 is needed by package nagios-plugins-load-1.4.15-2.el5.x86_64 (installed)
Error: Missing Dependency: nagios-plugins = 1.4.15-2.el5 is needed by package nagios-plugins-procs-1.4.15-2.el5.x86_64 (installed)
Error: Missing Dependency: nagios-plugins = 1.4.15-2.el5 is needed by package nagios-plugins-disk-1.4.15-2.el5.x86_64 (installed)
 You could try using --skip-broken to work around the problem
 You could try running: package-cleanup --problems
                        package-cleanup --dupes
                        rpm -Va --nofiles --nodigest
I don't know how this has happened, and I haven't been able to find any way to fix this so far, and that includes the suggestions in the above message. The plugins on the server seem to be working just fine.
Has anyone else come across this, and do you have a solution please?
Re: YUM update missing dependency
You can try and clean out the yum cache by running this. Sometimes they need to be cleaned out because the repo's are changed and the updates didn't download.
yum clean all
Then try and and then do update update and see if that works.
