Hi
I have a couple of problems.
1) my indoes is in use at 100%. when i run df -ih, i see
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/mapper/VolGroup-lv_root
1.1M 1.1M 1.3K 100% /
How can I empty out/remove the inodes.
2) I have nearly 5GB of data in XIDPE
How can i remove all contents of this folder.
I've tried "rm -rf *" however it errors out saying
-bash: /bin/rm: Argument list too long
Thanks in advance
Nagios - Inodes & XIDPE
Re: Nagios - Inodes & XIDPE
Hi
I've found a solution and run
"find . -type f -delete"
within /usr/local/nagios/var/spool/xidpe
This has deleted all contents of that directory.
Has also freed up inode space as well.
Thanks for posting back here. Shall we mark this post as solved and lock it up?
