The famous rw permission problem
amprantino
Post by amprantino »
I just upgraded to nagios v4 and I face the well-know issue with the nagios.cmd problem.
# /etc/init.d/nagios start
Starting nagios:/bin/chmod: cannot access ‘/var/log/nagios/rw/nagios.cmd’: No such file or directory
 done.
I save mine to /var/log/nagios/rw/nagios.cmd.
Is this value taken from nagios.cfg, and command_file=/var/log/nagios/rw/nagios.cmd ??
Because even if I change the path to command_file=/usr/local/nagios/var/rw/nagios.cmd , nothing changes.
Is this option ignored in v4?
As I am using Debian, I apply the following permissions:
mkdir /var/log/nagios/rw
chown nagios.www-data /var/log/nagios/rw
chmod u+rwx /var/log/nagios/rw
chmod g+rwx /var/log/nagios/rw
chmod g+s /var/log/nagios/rw
Any idea why these fail?
Re: The famous rw permission problem
Did you change both the init script /etc/init.d/nagios and the nagios.cfg file to the new folder?
Try that and let us know if it works for you.
If not, post the OS and version you are running and also the output of the following.
chage -l nagios
grep nag /etc/passwd
grep nag /etc/group
amprantino
/etc/init.d/nagios
NagiosCommandFile=/var/log/nagios/rw/nagios.cmd
nagios.cfg
Both files point to the same nagios.cmd file
# chage -l nagios
Last password change : Oct 30, 2012
Password expires : never
Password inactive : never
Account expires : never
Minimum number of days between password change : 0
Maximum number of days between password change : 99999
Number of days of warning before password expires : 7
# grep nag /etc/passwd
list:x:38:38:Mailing List Manager:/var/list:/usr/sbin/nologin
nagios:x:1001:1001:,,,:/usr/bin/:/bin/bash
systemd-network:x:108:114:systemd Network Management,,,:/run/systemd/netif:/bin/false
# grep nag /etc/group
nagios:x:1001:smsd
# uname -a
Linux NAME 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt20-1+deb8u3 (2016-01-17) x86_64 GNU/Linux
# cat /etc/debian_version
8.5
When I compiled, I got this output during configure:
Command user/group: www-data,nagios
and then:
# make install-commandmode
/usr/bin/install -c -m 775 -o www-data -g nagios -d /var/log/nagios/rw
The nagios group looks like it is missing some of the users from the list and that could be the issue.
Edit the /etc/group file and change this line from
nagios:x:1001:smsd
to
nagios:x:1001:nagios,www-data,smsd
Save the file and let us know if this works for you.
amprantino
I did the changes to the /etc/group.
The problem are the permissions of the "/var/log/nagios" directory.
If permissions are less than 775, nagios fail to access nagios.cmd
After playing around with permissions I think I should stick to these:
/var/log# ll -d nagios/
drwxrwxr-x 6 nagios nagios 4.0K Jul 26 11:19 nagios/
/var/log/nagios# ll -d rw
drwxrwsr-x 2 nagios nagios 4.0K Jul 26 11:17 rw
/var/log/nagios/rw# ll
total 8.0K
drwxrwsr-x 2 nagios nagios 4.0K Jul 26 11:17 .
drwxrwxr-x 6 nagios nagios 4.0K Jul 26 11:19 ..
prw-rw---- 1 nagios nagios 0 Jul 26 11:17 nagios.cmd
srw-rw---- 1 nagios nagios 0 Jul 26 11:17 nagios.qh
Are the above correct, of group should be www-data ?
The permissions look good for those folders.
As long as the www-data is part of the nagios group, it should work for you.
amprantino
When I compile nagios from source, which are the correct parameters for:
--with-command-user=www-data \
--with-command-grp=www-data \
This should match the nagios user or the apache user or ... ?
Based on these parameters, should I apply the permissions to "/var/log/nagios/rw"?
To keep everything consistent, I would use the following
--with-command-user=nagios \
--with-command-grp=nagios \
Then all you would have to do is make sure the nagios group has permissions for that folder and that the www-data is part of the nagios group.
amprantino
To sum up:
Compile with options
Apply permissions
/usr/bin/install -c -m 775 -o nagios -g nagios -d /var/log/nagios/rw
nagios group permissions
Thank you all
Shall we mark this post as solved and lock it up?
