A Database Error Occurred
Error Number: 1054
Unknown column 'type' in 'field list'
SELECT `username`, `username`, `email`, `id`, `password`, `active`, `last_login`, `apiaccess`, `apikey`, `lang`, `type`, `auth_server_id`, `auth_server_data` FROM (`nagiosna_users`) WHERE `username` = 'nagiosadmin' LIMIT 1
Filename: /var/www/html/nagiosna/application/models/ion_auth_model.php
Line Number: 886
Please help.
Starting httpd: (98)Address already in use: make_sock: could not bind to address [::]:80
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
[FAILED]
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'daemons'
telnet 127.0.0.1 80
Trying 127.0.0.1...
Connected to 127.0.0.1.
Escape character is '^]'.
/GET
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>301 Moved Permanently</title>
</head><body>
<h1>Moved Permanently</h1>
<p>The document has moved <a href="http://:8000/">here</a>.</p>
<hr>
<address>Apache/2.2.15 (CentOS) Server at fuel.qocp.planofoundry.com Port 80</address>
</body></html>
