NSClient ++ nsclient.ini help needed
kwhogster
Post by kwhogster »
Running Nagios 4.1.1 on a raspberry PI had some issues with NRPE on Raspbian so I decided to build another Nagios Server running on Ubuntu Server 16.04.1
All my configs copied over and all tested clean.
I just need to get the nsclient to point to the new server
I need to change this line
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = 10.2.8.72
To
allowed hosts = 10.2.8.79
but when I try to save the file I get access denied. I tried stopping the nsclient service but no luck
short of uninstalling and reinstalling is there a way to modify this nsclient.ini file ?
kwhogster
Re: NSClient ++ nsclient.ini help needed
Post by kwhogster »
Solved
open command prompt run as administrator
net stop nscp
notepad nsclient.ini
save nsclient.ini
net start nscp
Post by mcapra »
Thanks for sharing your solution! Is it alright if we lock this thread and mark the issue as resolved?
