Trying to setup plugin check_numoffiles.sh
joshtate2001
I have downloaded the check_numoffile.sh plugin to warn me if the number of files in a directory exceeds a particular number.
I have tried to follow their usage example but cannot get it to pass the pre-check.
At first the issue was the command was not defined any where. So, I started looking at \nagios\etc\objects\command.cfg
I cannot figure out the proper syntax in my command.cfg. Below is the line I have in mine now:
#'check_numoffiles' command definition
command_name check_numoffiles
command_line $USER1$/check_numoffiles -d $PATH$ -w $WARN$ -c $CRIT$
This is the service definition below from my server object config file:
use doceserve-services
host_name doc-e-serve
service_description Active Folder Check
check_command check_numoffiles -d C:\DoceServe\Active -w 2 -c 4
Also, I placed the plugin "check_numoffiles.ssh" in my /nagios/libexec folder.
I am running Nagios Core Version 4.0.8 with the plugins package.
Re: Trying to setup plugin check_numoffiles.sh
Could you share the guide you followed?
I assume you are referring to this plugin?
https://exchange.nagios.org/directory/P ... nt/details
Couple of things:
Your command definition uses the $PATH$, $WARN$, and $CRIT$ macros. Are these macros defined anywhere? Info about macros:
https://assets.nagios.com/downloads/nag ... acros.html
This Service definition is not properly formatted for passing arguments. Also, on the receiving end with your Command definition accepting arguments generally uses the built-in macros $ARG1$, $ARG2$, $ARG3$, $ARGn$. See the above macros document for further information on this.
Is your Nagios Core installation running on a Windows machine? That looks like a Windows file path, where as the check_numoffiles.sh plugin is written as a shell script. Shell scripts will not run on Windows typically without the introduction of something like cygwin.
Couple of things:
joshtate2001
The part here I was guessing.
joshtate2001
Nagios COre itself is running on Ubunto Linux. The folder it is checking is a windows host though.
They did not really have a guide to follow for this plugin. I found the plugin itself off the Nagios site.
joshtate2001
I change the code in command.cfg to the following based on the replies:
I am still running into the following error when I run the pre-check.
Error: Service check command 'check_numofffiles -d C:\DoceServe\Active -w 2 -c 4' specified in service 'Active Folder Check' for host 'doc-e-serve' not defined anywhere.
Below is the code for the service from the host object cfg file.
command_line $USER1$/check_numoffiles -d $ARG1$ -w $ARG2$ -c $ARG3$$
}Re: Trying to setup plugin check_numoffiles.sh
Your command definition has an extra $ on the 3rd argument. Your Service definition is pretty close! Example 2 in the docs I linked shows how to pass arguments in a Service definition:
Your Service definition should look like this:
It's also worth mentioning that Nagios Core by itself has virtually no way to talk to a remote Windows machine (except ping/telnet) unless that Windows machine has an agent installed. Here's a document that briefly describes the process of setting up an agent on a Windows machine and monitoring that machine:
https://assets.nagios.com/downloads/nag ... ndows.html
Looking at the source, the check_numoffiles plugin doesn't have a way to request information from a remote machine; Everything is local. Also since it is written as a shell script, it is not an ideal candidate for monitoring a Windows environment.
check_command check_numoffiles!C:\DoceServe\Active!2!4
joshtate2001
I have an agent both the old nsclient agent and the NRPE agent runningon the host windows machine.
I will fix my extra $ and the command line for the service and let you know. Thanks!!
joshtate2001
So, I am real close.
I was able to get things to pass the verification. However, I get the following warning from Nagios.
It is complaining about the path.
(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_numoffiles, ...) failed. errno is 2: No such file or directory
Command Code:
Service Code:
I think the issue now is the path or how I am passing it. Not sure if I need quotes, etc...
Command Code:
}Code: Select all
Are you certain the file /usr/local/nagios/libexec/check_numoffiles exists? The plugin I referenced is originally named check_nomoffiles.sh. If this is the plugin you are using, I would verify it's path. I would also make sure the nagios command group and user has permission to execute the script.
Also, if your intention is to use this plugin to check the number of files on a remote machine, you would need to put that script on the remote machine and execute it via check_nt, check_nrpe, or check_by_ssh.
joshtate2001
I have corrected the command syntax.
I now get (Return code of 13 is out of bounds) in the Nagios reported error.
Command Definition Code:
Service Definition Code:
command_name check_numoffiles.sh
command_line $USER1$/check_numoffiles.sh -d $ARG1$ -w $ARG2$ -c $ARG3$
}Code: Select all
check_command check_numoffiles.sh!C:\DoceServe\Active\!2!4
