configure naigos in cisco swith
ivp2015
Post by ivp2015 »
Hi Team,
We want to configure a cisco switch for monitoring could your please share the proper configuration documentation that how to add a template and switch snmp configuration
Re: configure naigos in cisco swith
In Nagios XI, the easiest way to monitor a switch would be the Switch and Router Monitoring Wizard, available under the Configure menu. You might also try the SNMP Walk Wizard if you are looking for more info. Both will require the correct SNMP community string.
