How to define the "Packets, Bytes, Flows, Packet/sec, Bytes/Packet"?
Thank you!
Ray
where is the data of column
Re: where is the data of column
Can you please clarify? Are you looking for a definition of those terms, or are you asking how to configure something in Network Analyzer? If you are asking how to configure something, please describe in detail what it is you want to achieve.
