nagios-base/primary FAILED
http://repo.nagios.com/nagios/7/repodata/8881a54830935071d84a1c8e43c626857133d0b7182268d847a411b5c4dd12e8-primary.xml.gz: [Errno 12] Timeout on http://repo.nagios.com/nagios/7/repodata/8881a54830935071d84a1c8e43c626857133d0b7182268d847a411b5c4dd12e8-primary.xml.gz: (28, 'Operation too slow. Less than 1000 bytes/sec transferred the last 30 seconds')
Trying other mirror.
nagiosxi-deps/primary FAILED
http://repo.nagios.com/nagiosxi-deps/7/repodata/fc575084d092cdc3a4c223f7e94b71e1eb7d4944f82793f9ba306c31cae7f6aa-primary.xml.gz: [Errno 12] Timeout on http://repo.nagios.com/nagiosxi-deps/7/repodata/fc575084d092cdc3a4c223f7e94b71e1eb7d4944f82793f9ba306c31cae7f6aa-primary.xml.gz: (28, 'Operation too slow. Less than 1000 bytes/sec transferred the last 30 seconds')
etc...
Yes, I'm behind a proxy, yes, repo.nagios.com is bypassed from filtering/decryption at the proxy
2: I thought I'd bypass this and just mirror the repo in Satellite. But Satellite syncing errors out with:
nagios-base/primary FAILED 99% [==========================================================================-] 2.8 kB/s | 25 MB 00:00:45 ETA
epel/x86_64/updateinfo FAILED 99% [==========================================================================-] 0.0 B/s | 25 MB --:--:-- ETA
http://mirrors.rit.edu/fedora/epel/7/x86_64/repodata/31b8ad7f35f59313d29864411ab85cd687a318e61ded69e258d4d3421abb975e-updateinfo.xml.bz2: [Errno 12] Timeout on http://mirrors.rit.edu/fedora/epel/7/x86_64/repodata/31b8ad7f35f59313d29864411ab85cd687a318e61ded69e258d4d3421abb975e-updateinfo.xml.bz2: (28, 'Operation too slow. Less than 1000 bytes/sec transferred the last 30 seconds')
^C
Yeah I'd double check that proxy - seems like might it be scanning the content and it's taking to long, or of course high network latency. Definitely let us know what you find out.
