Different timings reflected in Nagios XI and Nagios core
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
We are using Nagios XI 2014R2.7 in our project, we have four Nagios servers for one of the server we are facing timing issue.
Different time is reflecting in Nagios core and Nagios XI, there is a difference of an hour between both the timings kindly refer the highlighted part in the attached snapshot:
kindly suggest.
Thanks & Regards,
I2MP Team.
bwallace
Re: Different timings reflected in Nagios XI and Nagios core
Post by bwallace »
Can you post the output of the following commands? Want to check that system time, php timezone and mysql all align...
date
grep "date.timezone" /etc/php.ini
ls -l /etc/localtime
php -r 'echo date("D M j G:i:s T Y")."\n";'
mysql -uroot -pnagiosxi -e "SELECT NOW();"
mysql -uroot -pnagiosxi -e "SELECT @@global.time_zone;"
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
Please find the attached snapshot:
Thanks & Regards,
I2MP Team.
bwallace
Post by bwallace »
Thanks -
Your php time is 1 hour ahead of the mysql time. All you need to do is get the php time to align with the rest by editing /etc/php.ini and this doc has a section on it:
https://assets.nagios.com/downloads/nag ... m_Time.pdf
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
Kindly refer the attached snapshot, I have provided the snapshot of reference server as well on which the time reflected is correct:
As the result of comparison between defected server timings and reference server timings below are my finding:
1. In the defected server php timing is the correct timing.
2. We need to change MySQL timing as its 1hr behind the php time(actual time).
Kindly suggest your views on this.
Thanks & Regards,
I2MP Team.
Did you follow the instructions in our documentation?
rm /etc/localtime
cp /usr/share/zoneinfo/Europe/London /etc/localtime
When you run:
the output is:
/etc/localtime -> /usr/share/zoneinfo/
at least, this is what it is on the screenshot... It could be "cut off".
However, the output should be:
/etc/localtime -> /usr/share/zoneinfo/Europe/London
What is the output of the following command?
cat /etc/sysconfig/clock
BTW, I have seen cases when the system and php time would not sync before the server is rebooted. Have you tried rebooting the Nagios XI server?
RIDS_I2MP
Post by RIDS_I2MP »
Thanks Team,
We corrected the system time and rebooted the server, now all the timings are align to actual timing.
Thanks & Regards,
I2MP Team.
Post by mcapra »
Awesome! Is it alright if we lock this thread and mark the issue as resolved?
