Hi All,
can we able to provide monitoring for Microsoft Cluster resources ?
If so please help us to get the right plug-ins and method of monitoring.
Where we already monitoring the cluster Nodes.
Microsoft Cluster resource monitoring
Re: Microsoft Cluster resource monitoring
Have you looked at our Nagios Exchange site? There are a lot of plugins that may be useful, such as these:
https://exchange.nagios.org/directory/P ... er/details
https://exchange.nagios.org/directory/P ... pt/details
Uday Kumar
Hi Team,
Thanks for providing links.
We have used check_microsoft_cluster.vbs in windows 2008 server and we are getting correct output.
But when we used same script for 2012 server , we are getting the error which is attached below. can we use same script for 2012 servers ?
If so, please help us here to sort out the issue or let us know if there is any other available script for 2012 servers.
- 2012 server error.PNG (5.03 KiB) Viewed 8224 times
The file in your error is for check_files.vbs, this doesn't appear to be the same script as check_microsoft_cluster.vbs. There isn't even an occurence of the word 'NagiosPlugin' in it.
' NAME: check_microsoft_cluster.vbs
' VERSION: 1.0
' AUTHOR: Herbert Stadler ([email protected])
' COMMENT: Script for Checking MSCS Cluster resources
' for use with Nagios and NSClient++
' Modification History:
' 2010-04-15 Creation
' License Information:
' This program is free software; you can redistribute it and/or modify
' it under the terms of the GNU General Public License as published by
' the Free Software Foundation; either version 3 of the License, or
' (at your option) any later version.
' This program is distributed in the hope that it will be useful,
' but WITHOUT ANY WARRANTY; without even the implied warranty of
' MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
' GNU General Public License for more details.
' You should have received a copy of the GNU General Public License
' along with this program; if not, see <http://www.gnu.org/licenses/>.
' NAGIOS DEFINITIONS:
' ### command definition ###
' define command {
' command_name check_mscs
' command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -t 30 -c check_mscs -a "$ARG1$" "$ARG2$"
' ### service definition ###
' define service{
' use generic-service
' host_name CLUSTERPPCL
' service_description Microsoft Cluster Resources
' process_perf_data 0
' check_command check_mscs!CLRES!"SQL Server,Disk S:"
' or
' check_command check_mscs!"CLRES"
' check_command check_mscs!"CLRESP"
' check_command check_mscs!"CLNODE"
Option explicit
Dim strArglist
Dim strWmiQuery
Dim strResName
Dim strNodeName
Dim strResultCritical
Dim strResultWarning
Dim strStatus
Dim arrResNames
Dim arrNodeNames
Dim objArgs
Dim objItem
Dim objWMIService
Dim colItems
Dim i
Dim strArg, objArg
Dim strCommand
Dim CheckedElement
Dim objCluster
'RC to NAGIOS
Const intOK = 0
Const intWarning = 1
Const intCritical = 2
Const intUnknown = 3
' if someone want's to switch off checking of "not defined" preferred cluster node of resource groups
Const strCHECK_EMPTY_PREFERREDNODE = "ON"
strResultCritical = ""
strResultWarning = ""
Set objArgs = WScript.Arguments
if objArgs.Count = 0 then
Display_Usage()
end if
for Each objArg In objargs
strArg = LCase(objArg)
Select Case strArg
Case "-h"
Display_Usage()
Case "--help"
Display_Usage()
Case "-help"
Display_Usage()
Case "-?"
Display_Usage()
Case "/?"
Display_Usage()
Case "/h"
Display_Usage()
End Select
Next
strCommand=UCase(objArgs(0))
strArglist=""
if strCommand = "CLRES" or strCommand = "CLNODE" or strCommand = "CLRESP" Then
If objArgs.Count > 1 Then
for i = 1 to objArgs.Count - 1
if objArgs(i) = "$ARG2$" or _
objArgs(i) = "$ARG3$" or _
objArgs(i) = "$ARG4$" then
else
If strArglist = "" Then
strArglist = objArgs(i)
Else
strArglist = strArglist & " " & objArgs(i)
End If
end if
next
End if
End if
Set objCluster = CreateObject("MSCluster.Cluster")
objCluster.Open ""
Set objWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}!\\.\root\mscluster")
Select Case strCommand
Case "CLRES"
Check_CLRES(strCommand)
Case "CLRESP"
Case "CLNODE"
arrNodeNames = Split(strArglist, ",")
strWmiQuery = "Select * from MSCluster_Node"
Set colItems = objWMIService.ExecQuery(strWmiQuery)
if Entered_Values_Wrong(colItems,arrNodeNames) then
Wscript.StdOut.WriteLine "Entered NodeNames wrong: " & CheckedElement
WScript.Quit(intUnknown)
end if
For Each objItem in colItems
do while true
if not Object_in_Array(objItem.Name, arrNodeNames) then
exit do
End if
strStatus=Explain_Node_State (objItem.State)
If strStatus = "paused" or strStatus = "joining" Then
if strResultWarning <> "" then
strResultWarning=strResultWarning & ", "
end if
strResultWarning = strResultWarning & objItem.Name & " (" & strStatus & ")"
End If
If strStatus = "down" or strStatus = "unknown" Then
if strResultCritical <> "" then
strResultCritical=strResultCritical & ", "
end if
strResultCritical = strResultCritical & objItem.Name & " (" & strStatus & ")"
End If
exit do
loop
next
If strResultWarning = "" and strResultCritical = "" Then
Wscript.StdOut.WriteLine "OK - Clusternodes"
WScript.Quit(intOK)
End If
If strResultCritical = "" Then
Wscript.StdOut.WriteLine "WARNING - Clusternodes: " & strResultWarning
WScript.Quit(intWarning)
Else
dim strMsgOut
strMsgOut="CRITICAL - Clusternodes: " & strResultCritical
strMsgOut=strMsgOut & ", " & strResultWarning
end if
Wscript.StdOut.WriteLine strMsgOut
WScript.Quit(intCritical)
End If
Case "LIST"
wscript.StdOut.WriteLine "List of Cluster Resource Information"
wscript.StdOut.WriteLine "------------------------------------"
strWmiQuery = "Select * from MSCluster_Resource"
wscript.StdOut.WriteLine Make_Length(objItem.Name,40) & vbTab & Explain_Res_State (objItem.State) & vbTab & objItem.Status
next
wscript.StdOut.WriteLine ""
wscript.StdOut.WriteLine "List of Cluster Node Information"
wscript.StdOut.WriteLine "----------------------------------"
wscript.StdOut.WriteLine objItem.Name & vbTab & vbTab & Explain_Node_State (objItem.State) & vbTab & objItem.Status
next
wscript.StdOut.WriteLine "List of Cluster Network Information"
wscript.StdOut.WriteLine "-----------------------------------"
strWmiQuery = "Select * from MSCluster_Network"
wscript.StdOut.WriteLine Make_Length(objItem.Name,20) & vbTab & Explain_Net_State (objItem.State) & vbTab & objItem.Status
next
wscript.StdOut.WriteLine "List of Cluster Resource Group Information"
wscript.StdOut.WriteLine "------------------------------------------"
strWmiQuery = "Select * from MSCluster_ResourceGroup"
wscript.StdOut.WriteLine Make_Length(objItem.Name,20) & vbTab & Explain_Group_State (objItem.State) & vbTab & objItem.Status & vbTab & objItem.AutoFailbackType
next
wscript.StdOut.WriteLine "List of Cluster Resource Group Preferred Node Information"
wscript.StdOut.WriteLine "---------------------------------------------------------"
strWmiQuery = "Select * from MSCluster_ResourceGroupToPreferredNode"
wscript.StdOut.WriteLine Make_Length(objItem.GroupComponent,20) & vbTab & objItem.PartComponent
next
Dim res
Dim resGroup
For Each res in objCluster.Nodes
For Each resGroup in res.ResourceGroups
If (resGroup.PreferredOwnerNodes.count > 0) Then
For i=1 To resGroup.PreferredOwnerNodes.count
if resGroup.OwnerNode.Name <> resGroup.PreferredOwnerNodes.Item(i).Name then
wscript.StdOut.WriteLine "!!WARNING!! Resource Group " & resGroup.Name & " not on PreferredNode " & resGroup.PreferredOwnerNodes.Item(i).Name
end if
next
else
wscript.StdOut.WriteLine "!!WARNING!! Resource Group " & resGroup.Name & " no PreferredNode set"
end if
next
next
wscript.StdOut.WriteLine "List of Cluster Resource Type Information"
wscript.StdOut.WriteLine "-----------------------------------------"
strWmiQuery = "Select * from MSCluster_ResourceType"
wscript.StdOut.WriteLine Make_Length(objItem.Name,20) & vbTab & objItem.Status
next
wscript.StdOut.WriteLine "List of Cluster Service Information"
strWmiQuery = "Select * from MSCluster_Service"
wscript.StdOut.WriteLine Make_Length(objItem.Name,20) & vbTab & objItem.SystemName & vbTab & objItem.State & vbTab & objItem.Status
next
wscript.StdOut.WriteLine "List of Cluster Information"
wscript.StdOut.WriteLine "---------------------------"
strWmiQuery = "Select * from MSCluster_Cluster"
next
WScript.Quit(intOK)
Case else
Wscript.StdOut.WriteLine "Parameter wrong: " & strCommand
End Select
Function Check_CLRES (strCommand)
arrResNames = Split(strArglist, ",")
if Entered_Values_Wrong(colItems,arrResNames) then
Wscript.StdOut.WriteLine "Entered ResourceNames wrong: " & CheckedElement
end if
do while true
if not Object_in_Array(objItem.Name, arrResNames) then
exit do
End if
strStatus=Explain_Res_State (objItem.State)
If strStatus <> "online" Then
end if
End If
exit do
Loop
Next
if ( strCommand = "CLRESP" ) Then
dim strPrefNode
strPrefNode=Check_ClusterResource_PreferredNode()
if ( strPrefNode <> "" ) then
Wscript.StdOut.WriteLine "WARNING - Clusterresource: " & strPrefNode & " not on preferred node"
End If
end if
Wscript.StdOut.WriteLine "OK - Clusterresource"
WScript.Quit(intOK)
Else
Wscript.StdOut.WriteLine "CRITICAL - Clusterresource: " & strResultCritical
End If
End Function
Function Check_ClusterResource_PreferredNode ()
Dim res
Dim resGroup
Dim strResult
strResult=""
strResult=Build_String(strResult,resGroup.Name)
Exit For
end if
next
else
if ( strCHECK_EMPTY_PREFERREDNODE = "ON" ) Then
End If
end if
next
next
Check_ClusterResource_PreferredNode=strResult
End Function
Function Build_String (strResult,strName)
if ( strResult <> "" ) then
strResult=strResult & ", "
end if
strResult=strResult & strName
Build_String=strResult
End Function
Function Explain_Node_State (state)
dim strStatus
Select Case state
Case 0 strStatus = "up"
Case 1 strStatus = "down"
Case 2 strStatus = "paused"
Case 3 strStatus = "joining"
Case Else strStatus = "unknown"
End Select
Explain_Node_State=strStatus
End Function
Function Explain_Group_State (state)
dim strStatus
Select Case state
Case 0 strStatus = "Online"
Case 1 strStatus = "Offline"
Case 2 strStatus = "Failed"
Case 3 strStatus = "PartialOnline"
Case 4 strStatus = "Pending"
Case Else strStatus = "StateUnknown"
End Select
Explain_Group_State=strStatus
End Function
Function Explain_Net_State (state)
dim strStatus
Select Case state
Case 0 strStatus = "StateUnavailable"
Case 1 strStatus = "Down"
Case 2 strStatus = "Partitioned"
Case 3 strStatus = "Up"
End Select
Explain_Net_State=strStatus
End Function
Function Explain_Res_State (state)
dim strStatus
Select Case state
Case 2 strStatus = "online"
Case 3 strStatus = "offline"
Case 4 strStatus = "failed"
Case 129 strStatus = "online pending"
Case 130 strStatus = "offline pending"
End Select
Explain_Res_State=strStatus
End Function
Function Display_Usage
Wscript.StdOut.WriteLine ""
Wscript.StdOut.WriteLine "Check Microsoft Cluster Usage"
Wscript.StdOut.WriteLine " check_microsoft_cluster.vbs CLRES [resource list]" & vbcrlf
wscript.StdOut.WriteLine " same as above with checking if owner = preferred owner (preferred node)"
Wscript.StdOut.WriteLine " check_microsoft_cluster.vbs CLRESP [resource list]" & vbcrlf
Wscript.StdOut.WriteLine " check_microsoft_cluster.vbs CLNODE [node list]"
Wscript.StdOut.WriteLine vbcrlf & " for debugging purposes:"
Wscript.StdOut.WriteLine " check_microsoft_cluster.vbs LIST"
Wscript.StdOut.WriteLine vbTab & "resource list list of MSCS resource names to be monitored"
Wscript.StdOut.WriteLine vbTab & "node list list of MSCS node names to be monitored"
Wscript.StdOut.WriteLine "List items are comma separated."
WScript.Quit(intOK)
End Function
Function Make_Length (sstr, slen)
Dim istrlen
istrlen=len(sstr)
istrlen = slen - istrlen
if istrlen > 0 then
Make_Length=sstr & space(istrlen)
else
Make_Length=sstr
End If
End Function
Function Object_in_Array(strName, arrNames)
dim strElement
if ubound(arrNames) < 0 then
Object_in_Array=true
exit function
end if
For Each strElement in arrNames
if StrComp(strName,strElement,0) = 0 then
exit function
end if
Next
Object_in_Array=false
End Function
function Entered_Values_Wrong(colItems,arrNames)
dim strElement
dim sFound
Entered_Values_wrong=false
exit function
end if
sFound=false
CheckedElement=strElement
if objItem.Name = strElement then
sFound=true
end if
next
if sFound = false then
Entered_Values_wrong=true
exit function
end if
next
end function
Uday Kumar
Hi Kennedy,
Thanks for your inputs.
For 2008 server, script is working fine in remote host.
But when we are calling from Nagios, we are facing below issue.
[root@ libexec]# ./check_nrpe -H xxxxxxxxx -c check_mscs -a CLRES
No handler for command: check_mscs
Please find the attached Nsclient file
Nsclient.ini- (9.63 KiB) Downloaded 479 times
- Former Nagios Staff
Is check_files.vbs calling check_microsoft_cluster.vbs ? If so, could you try running check_microsoft_cluster.vbs directly?
Uday Kumar
HI,
The problem facing for 2008 servers got fixed and we are able to monitor cluster resources of those servers.
But when we use same microsoft_cluster.vbs in 2012 server , we are getting the below attached error.
Can you please assist us here.
- Cluster.PNG (6 KiB) Viewed 8188 times
Per this post, it will not work in 2012 so you would need to re-write the plugin, or look for one that will work on 2012.
https://social.technet.microsoft.com/Fo ... forum=ITCG
