Hello everyone,
I have added almost 300 services, and I need to change the value of the "check interval" from 1 to 5 on all those 300 services ...
Is there a way to do it for all ? or do I have to do it manually on each service ?
Thank you
change check interval for all services
Re: change check interval for all services
If you have a template in use by all of the services and you are defining the check_interval in that template, then changing that template should suffice. Otherwise, we do have a tool called the Bulk Modifications Tool in the Enterprise Edition feature set. There is a (somewhat older) video of ours that shows exactly what you are wanting to do:
https://www.youtube.com/watch?v=3wsLAMR4V2Y
If you have not done so already, you can enable a free 60-day trial of the Enterprise Edition features to get access to this tool.
nagios_aws
thank you for your answer, I didn't know about this tool, I used it and it works perfect.
It will ease further changes
Great to hear it! Is it alright if we close this thread now?
nagios_aws
Yeah, sorry, forgot to tell you to do it
thank you !
thank you !
