Hi All,
I am working for a Customer where I have created a NagVis map and they are asking me for a Geo Map.
-- We are using Icons for host_groups and lines for BPI's services.
They want to do the same thing but in a geomap where they can make zoom on the locations and that kind of things.
Do Nagios XI 5 has something to do it? Or do I have an add-on alternative?
I have followed this how_to: http://docs.nagvis.org/1.8/en_US/geomap.html
However, it hasn't work ok - Nagios XI 5 uses NagVis 1.5 but not 1.7/8
Regards,
NagiosXI 5 - GeoMap
Re: NagiosXI 5 - GeoMap
Yes there is an alternative - XI has a Google map component ( & dashlet) which may be a better fit.
In the XI UI go to Admin > System Extensions > Manage Dashlets and look for the Google Map dashlet. To use it you must 1st download and install the component - follow this doc on how to do install the component, it's quick and easy.
https://assets.nagios.com/downloads/na ... 1456514247
Once you've install the Google Map component, this doc will walk you through the rest of the configuration.
https://assets.nagios.com/downloads/nag ... 1456514247
Let us know if this will work out for you and if there are any questions, thanks.
maartin.pii
Thanks in advance for your answer @bwallace.
This thread can be closed.
Regards,
Regards,
You're welcome. I'll go ahead and close this thread now and of course feel free to open another should you have any other questions.
