After upgrade log tables are blank
a pic is worth a thousand mistyped words lol:
seriously though, this is bad.
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
- Box293
- Too Basu
Re: After upgrade log tables are blank
Please CTRL + F5 to refresh your browser cache.
Does this fix the issue?
no the problem remains
Proudly running:
Nagios Fusion
Nagios Fusion
This is odd, just to make sure this isn't a server side issue, could you please try using a different browser / manually clearing your cache? We saw this come up recently, but it was just because of temporary cache.
Are you seeing the same results after testing?
you were correct tried it in IE and im good. thanks guys!
Proudly running:
Nagios Fusion
Nagios Fusion
