Using the Box293 plugin for VMware Esxi monitoring
Nagios Core 4.1.1 on Ubuntu Server 16.04.1
I created a vmware.cfg located/usr/local/Nagios/etc/objects
updated /usr/local/nagios/etc/nagios.cfg to include the new cfg file vmware.cfg so far all good
I created services for this plugin and I get this warning on some of them
Warning: Service 'Guest Snapshots' on host 'SERV014' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'ESXi Version' on host 'ESXIHOSTVM' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Here are the definitions:
# Host OS Name and Version
host_name ESXIHOSTVM
service_description ESXi Version
check_command box293_check_vmware!$HOSTADDRESS$!Host_OS_Name_Version!!!!!!
initial_state u
max_check_attempts 3
check_interval 1440
retry_interval 7
active_checks_enabled 1
check_period 24x7
register 1
# Guest Snapshots
host_name SERV014
service_description Guest Snapshots
check_command box293_check_vmware!10.2.8.21!Guest_Snapshot!--guest!FileServer!--warning!snapshot_age:5!--critical!snapshot_age:10
initial_state u
check_interval 240
retry_interval 7
check_period 24x7
register 1
is it my check_interval value?
Thoughts suggestions?
Thank you
Warnings on Service defs incfg file
Re: Warnings on Service defs incfg file
changed to check_interval 1440 to check_interval 10
changed check_interval 240 to check_interval 10
Now no warnings
solved this
Now no warnings
solved this
Looks like you solved a few things over the weekend! Mind if we lock this?
Yes this can be closed thanks
