(Return code of 125 is out of bounds)
kwhogster
Post by kwhogster »
Nagios Core 4.1.1 on Ubuntu Server 16.04.1
I have a vMA Host 6.0
ESXi Host 6.0
Just added box293_check_vmware plugin
built a vMA Host all seems ok
When I created a new cfg file VMware.cfg with my host and guests defined
I created a new command in my commands.cfg file
	command_name box293_check_vmware
	command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H 10.2.8.7 -C "nice -n19~/box293_check_vmware.pl --server $ARG1$ --check $ARG2$ \"$ARG3$\" \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
I added to the nagios.cfg
# BOX293 config settings
cfg_file=/usr/local/nagios/etc/objects/vmware.cfg
a sample of my VMware.cfg
#  Define HOST
        use             windows-server  ; Inherit default values from a template
        host_name       ESXIHOSTVM      ; The name we're giving to this host
        alias           ESXi 6.0	; A longer name associated with the host
        address         10.2.8.10       ; IP address of the host
# 	Host OS Name and Version
	service_description ESXi Version
	check_command box293_check_vmware!$HOSTADDRESS$!Host_OS_Name_Version!!!!!!
	initial_state u
	max_check_attempts 3
#	check_interval 1440
	check_interval 10
	retry_interval 7
	active_checks_enabled 1
	check_period 24x7
	register 1
#	Host Storage Adapter Performance
	service_description HBA Performance - vmhba1
	check_command box293_check_vmware!$HOSTADDRESS$!Host_Storage_Adapter_Performance!--name!vmhba1!!!!
	initial_state u
	check_interval 5
	retry_interval 3
	check_period 24x7
	register 1
#	Guest CPU Usage
	host_name SERV014
	service_description Guest CPU Usage
	check_command box293_check_vmware!10.2.8.21!Guest_CPU_Usage!--guest!FileServer!!!!
	initial_state u
	check_interval 5
	retry_interval 3
	check_period 24x7
	register 1
	host_name SERV015
	check_command box293_check_vmware!10.2.8.22!Guest_CPU_Usage!--guest!FileServer!!!!
	initial_state u
	check_interval 5
	retry_interval 3
	check_period 24x7
	register 1
Why am I getting (Return code of 125 is out of bounds) on all my service definitions?
kwhogster
Re: (Return code of 125 is out of bounds)
Post by kwhogster »
box293 replied to my email
he found this error in my command.cfg file
should be like this
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H 10.2.8.7 -C "nice -n19 ~/box293_check_vmware.pl --server $ARG1$ --check $ARG2$ \"$ARG3$\" \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
no space -n19~ need to be -n19 ~
Now the (Return code of 125 is out of bounds) is gone
Now just have a warning
Enter username: Error :: Invalid argument specified
Thoughts
Post by Box293 »
I am helping you through email, probably best not to continue to post here.
kwhogster
Post by kwhogster »
close this as resolved
Thank you
bwallace
Post by bwallace »
Appreciate the update - closing this one out now.
