Bandwidth usage Graphs
raamardhani7
Post by raamardhani7 »
Hi Team,
We have configured NNA and added two sources to have the netflow data. We could see the details, but we are unable to see the Bandwidth utilization graphs.
Could you please help us here.
Please find the updates on few details.
 ls -al /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8
total 32
drwxr-sr-x+ 3 nna nnacmd  4096 Aug  1 07:56 .
drwsrwsr-x+ 5 nna nnacmd  4096 Jul 29 07:45 ..
-rw-r--r--+ 1 nna nnacmd     5 Aug  1 07:56 9998.pid
drwxr-sr-x+ 2 nna nnacmd 16384 Aug  1 08:25 flows
rrdtool
RRDtool 1.4.9  Copyright 1997-2013 by Tobias Oetiker <[email protected]>
               Compiled Jul 27 2016 22:01:47
Usage: rrdtool [options] command command_options
Valid commands: create, update, updatev, graph, graphv,  dump, restore,
                last, lastupdate, first, info, fetch, tune,
                resize, xport, flushcached
RRDtool is distributed under the Terms of the GNU General
Public License Version 2. (www.gnu.org/copyleft/gpl.html)
For more information read the RRD manpages
iptables -L -n
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0           udp dpt:9998
ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0           udp dpt:9995
ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0           udp dpt:9996
ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           tcp dpt:9998
ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0           udp dpt:12354
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
ps -ef | grep [n]na
nna       8183     1  0 07:56 ?        00:00:00 /usr/local/bin/nfcapd -I 11 -l /usr/local/nagiosna/var/ASA172.22.249.254/flows -p 9996 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/ASA172.22.249.254/9996.pid -D -e -w -z
nna       8184  8183  0 07:56 ?        00:00:00 /usr/local/bin/nfcapd -I 11 -l /usr/local/nagiosna/var/ASA172.22.249.254/flows -p 9996 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/ASA172.22.249.254/9996.pid -D -e -w -z
nna       8215     1  0 07:56 ?        00:00:00 /usr/local/bin/nfcapd -I 12 -l /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows -p 9995 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/NagiosFusionRCD83_98/9995.pid -D -e -w -z
nna       8217  8215  0 07:56 ?        00:00:00 /usr/local/bin/nfcapd -I 12 -l /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows -p 9995 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/NagiosFusionRCD83_98/9995.pid -D -e -w -z
nna       8247     1  0 07:56 ?        00:00:00 /usr/local/bin/nfcapd -I 14 -l /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows -p 9998 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/9998.pid -D -e -w -z
nna       8248  8247  0 07:56 ?        00:00:00 /usr/local/bin/nfcapd -I 14 -l /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows -p 9998 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/9998.pid -D -e -w -z
find / -name librrd.so.4
/tmp/nagiosna/rrdtool-1.4.9/src/.libs/librrd.so.4
/usr/local/lib/librrd.so.4
/usr/lib64/librrd.so.4
ls -la /usr/local/lib/librrd.so.4
lrwxrwxrwx 1 root root 15 Jul 27 22:01 /usr/local/lib/librrd.so.4 -> librrd.so.4.2.2
 tcpdump -vv host 10.10.130.8
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
^C
0 packets captured
0 packets received by filter
0 packets dropped by kernel
tcpdump port 9998
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
^C
0 packets captured
tail -100 /usr/local/nagiosna/var/backend.log
2016-08-01 08:00:00 INFO : Ran checks successfully
2016-08-01 08:00:00 INFO : Successfully reaped nfcapd file.
2016-08-01 08:00:03 INFO : Parsing data for the source id: 12
2016-08-01 08:00:03 DEBUG : Arguments: /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows, nfcapd.201608010755, 12
2016-08-01 08:00:03 DEBUG : Running checks...
2016-08-01 08:00:03 DEBUG : Getting relevant checks for source id: 12
2016-08-01 08:00:03 DEBUG : Checks found: ()
2016-08-01 08:00:03 INFO : Ran checks successfully
2016-08-01 08:00:03 INFO : Successfully reaped nfcapd file.
2016-08-01 08:00:10 INFO : Parsing data for the source id: 14
2016-08-01 08:00:10 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608010755, 14
2016-08-01 08:00:10 DEBUG : Running checks...
2016-08-01 08:00:10 DEBUG : Getting relevant checks for source id: 14
2016-08-01 08:00:10 DEBUG : Checks found: ()
2016-08-01 08:00:10 INFO : Ran checks successfully
2016-08-01 08:00:10 INFO : Successfully reaped nfcapd file.
2016-08-01 08:05:00 INFO : Parsing data for the source id: 11
2016-08-01 08:05:00 DEBUG : Arguments: /usr/local/nagiosna/var/ASA172.22.249.254/flows, nfcapd.201608010800, 11
2016-08-01 08:05:00 DEBUG : Running checks...
2016-08-01 08:05:00 DEBUG : Getting relevant checks for source id: 11
2016-08-01 08:05:00 DEBUG : Checks found: ()
2016-08-01 08:05:00 INFO : Ran checks successfully
2016-08-01 08:05:00 INFO : Successfully reaped nfcapd file.
2016-08-01 08:05:08 INFO : Parsing data for the source id: 12
2016-08-01 08:05:08 DEBUG : Arguments: /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows, nfcapd.201608010800, 12
2016-08-01 08:05:08 DEBUG : Running checks...
2016-08-01 08:05:08 DEBUG : Getting relevant checks for source id: 12
2016-08-01 08:05:08 DEBUG : Checks found: ()
2016-08-01 08:05:08 INFO : Ran checks successfully
2016-08-01 08:05:08 INFO : Successfully reaped nfcapd file.
2016-08-01 08:05:10 INFO : Parsing data for the source id: 14
2016-08-01 08:05:10 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608010800, 14
2016-08-01 08:05:10 DEBUG : Running checks...
2016-08-01 08:05:10 DEBUG : Getting relevant checks for source id: 14
2016-08-01 08:05:10 DEBUG : Checks found: ()
2016-08-01 08:05:10 INFO : Ran checks successfully
2016-08-01 08:05:10 INFO : Successfully reaped nfcapd file.
2016-08-01 08:10:02 INFO : Parsing data for the source id: 11
2016-08-01 08:10:02 DEBUG : Arguments: /usr/local/nagiosna/var/ASA172.22.249.254/flows, nfcapd.201608010805, 11
2016-08-01 08:10:02 DEBUG : Running checks...
2016-08-01 08:10:02 DEBUG : Getting relevant checks for source id: 11
2016-08-01 08:10:02 DEBUG : Checks found: ()
2016-08-01 08:10:02 INFO : Ran checks successfully
2016-08-01 08:10:02 INFO : Successfully reaped nfcapd file.
2016-08-01 08:10:10 INFO : Parsing data for the source id: 12
2016-08-01 08:10:10 DEBUG : Arguments: /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows, nfcapd.201608010805, 12
2016-08-01 08:10:10 DEBUG : Running checks...
2016-08-01 08:10:10 DEBUG : Getting relevant checks for source id: 12
2016-08-01 08:10:10 DEBUG : Checks found: ()
2016-08-01 08:10:10 INFO : Ran checks successfully
2016-08-01 08:10:10 INFO : Successfully reaped nfcapd file.
2016-08-01 08:10:10 INFO : Parsing data for the source id: 14
2016-08-01 08:10:10 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608010805, 14
2016-08-01 08:10:10 DEBUG : Getting relevant checks for source id: 14
2016-08-01 08:15:01 INFO : Parsing data for the source id: 11
2016-08-01 08:15:01 DEBUG : Arguments: /usr/local/nagiosna/var/ASA172.22.249.254/flows, nfcapd.201608010810, 11
2016-08-01 08:15:01 DEBUG : Running checks...
2016-08-01 08:15:01 DEBUG : Getting relevant checks for source id: 11
2016-08-01 08:15:01 DEBUG : Checks found: ()
2016-08-01 08:15:01 INFO : Ran checks successfully
2016-08-01 08:15:01 INFO : Successfully reaped nfcapd file.
2016-08-01 08:15:03 INFO : Parsing data for the source id: 12
2016-08-01 08:15:03 DEBUG : Arguments: /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows, nfcapd.201608010810, 12
2016-08-01 08:15:03 DEBUG : Running checks...
2016-08-01 08:15:03 DEBUG : Getting relevant checks for source id: 12
2016-08-01 08:15:03 DEBUG : Checks found: ()
2016-08-01 08:15:03 INFO : Ran checks successfully
2016-08-01 08:15:03 INFO : Successfully reaped nfcapd file.
2016-08-01 08:15:10 INFO : Parsing data for the source id: 14
2016-08-01 08:15:10 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608010810, 14
2016-08-01 08:15:10 DEBUG : Running checks...
2016-08-01 08:15:10 DEBUG : Getting relevant checks for source id: 14
2016-08-01 08:15:10 DEBUG : Checks found: ()
2016-08-01 08:15:10 INFO : Ran checks successfully
2016-08-01 08:15:10 INFO : Successfully reaped nfcapd file.
2016-08-01 08:20:01 INFO : Parsing data for the source id: 11
2016-08-01 08:20:01 DEBUG : Arguments: /usr/local/nagiosna/var/ASA172.22.249.254/flows, nfcapd.201608010815, 11
2016-08-01 08:20:01 DEBUG : Running checks...
2016-08-01 08:20:01 DEBUG : Getting relevant checks for source id: 11
2016-08-01 08:20:01 DEBUG : Checks found: ()
2016-08-01 08:20:01 INFO : Ran checks successfully
2016-08-01 08:20:01 INFO : Successfully reaped nfcapd file.
2016-08-01 08:20:08 INFO : Parsing data for the source id: 12
2016-08-01 08:20:08 DEBUG : Arguments: /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows, nfcapd.201608010815, 12
2016-08-01 08:20:08 DEBUG : Running checks...
2016-08-01 08:20:08 DEBUG : Getting relevant checks for source id: 12
2016-08-01 08:20:08 DEBUG : Checks found: ()
2016-08-01 08:20:08 INFO : Ran checks successfully
2016-08-01 08:20:08 INFO : Successfully reaped nfcapd file.
2016-08-01 08:20:10 INFO : Parsing data for the source id: 14
2016-08-01 08:20:10 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608010815, 14
2016-08-01 08:20:10 DEBUG : Running checks...
2016-08-01 08:20:10 DEBUG : Getting relevant checks for source id: 14
2016-08-01 08:20:10 DEBUG : Checks found: ()
2016-08-01 08:20:10 INFO : Ran checks successfully
2016-08-01 08:20:10 INFO : Successfully reaped nfcapd file.
tail -200 /var/log/httpd/error_log
[Sun Jul 31 03:21:08 2016] [notice] Digest: generating secret for digest authentication ...
[Sun Jul 31 03:21:08 2016] [notice] Digest: done
[Sun Jul 31 03:21:08 2016] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips mod_wsgi/3.2 Python/2.6.6 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sun Jul 31 22:10:06 2016] [error] [client 10.10.80.31] File does not exist: /var/www/html/robots.txt
[Sun Jul 31 22:10:06 2016] [error] [client 10.10.80.31] File does not exist: /var/www/html/favicon.ico
[Mon Aug 01 00:43:52 2016] [error] [client 172.30.245.235] File does not exist: /var/www/html/favicon.ico
ERROR: opening '/usr/local/nagiosna/var/NagiosFusionRCD83_98/bandwidth.rrd': No such file or directory
ERROR: opening '/usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/bandwidth.rrd': No such file or directory
ERROR: opening '/usr/local/nagiosna/var/ASA172.22.249.254/bandwidth.rrd': No such file or directory
[b]ERROR: opening '/usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/bandwidth.rrd': No such file or directory
ERROR: opening '/usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/bandwidth.rrd': No such file or directory[/b]
[Mon Aug 01 07:43:19 2016] [error] [client 172.30.245.235] File does not exist: /var/www/html/favicon.ico
Re: Bandwidth usage Graphs
The output from the tcpdump commands show that there isn't any Netflow data getting sent to the server so that could be the issue.
Try disabling the firewall on the Network Analyzer system and see if that helps.
Then login as root on the server, run the following commands and post the output.
getenforce
chage -l nna
grep nna /etc/group
ps -ef --cols=300
raamardhani7
tgriep wrote:The output from the tcpdump commands show that there isn't any Netflow data getting sent to the server so that could be the issue.
getenforce
chage -l nna
grep nna /etc/group
ps -ef --cols=300
Hi Tom,
Please find the output for the ones asked for.
getenforce
Disabled
chage -l nna
Last password change                                    : May 10, 2016
Password expires                                        : never
Password inactive                                       : never
Account expires                                         : never
Minimum number of days between password change          : 0
Maximum number of days between password change          : 99999
Number of days of warning before password expires       : 7
grep nna /etc/group
apache:x:48:nna
nnacmd:x:502:nna,apache
ps -ef --cols=300
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 Jul20 ?        00:00:00 /sbin/init
root         2     0  0 Jul20 ?        00:00:00 [kthreadd]
root         3     2  0 Jul20 ?        00:00:04 [migration/0]
root         4     2  0 Jul20 ?        00:01:52 [ksoftirqd/0]
root         5     2  0 Jul20 ?        00:00:00 [stopper/0]
root         6     2  0 Jul20 ?        00:00:00 [watchdog/0]
root         7     2  0 Jul20 ?        00:00:04 [migration/1]
root         8     2  0 Jul20 ?        00:00:00 [stopper/1]
root         9     2  0 Jul20 ?        00:01:55 [ksoftirqd/1]
root        10     2  0 Jul20 ?        00:00:00 [watchdog/1]
root        11     2  0 Jul20 ?        00:00:23 [events/0]
root        12     2  0 Jul20 ?        00:00:42 [events/1]
root        13     2  0 Jul20 ?        00:00:00 [cgroup]
root        14     2  0 Jul20 ?        00:00:00 [khelper]
root        15     2  0 Jul20 ?        00:00:00 [netns]
root        16     2  0 Jul20 ?        00:00:00 [async/mgr]
root        17     2  0 Jul20 ?        00:00:00 [pm]
root        18     2  0 Jul20 ?        00:00:02 [sync_supers]
root        19     2  0 Jul20 ?        00:00:02 [bdi-default]
root        20     2  0 Jul20 ?        00:00:00 [kintegrityd/0]
root        21     2  0 Jul20 ?        00:00:00 [kintegrityd/1]
root        22     2  0 Jul20 ?        00:00:05 [kblockd/0]
root        23     2  0 Jul20 ?        00:00:06 [kblockd/1]
root        24     2  0 Jul20 ?        00:00:00 [kacpid]
root        25     2  0 Jul20 ?        00:00:00 [kacpi_notify]
root        26     2  0 Jul20 ?        00:00:00 [kacpi_hotplug]
root        27     2  0 Jul20 ?        00:00:00 [ata_aux]
root        28     2  0 Jul20 ?        00:00:00 [ata_sff/0]
root        29     2  0 Jul20 ?        00:00:00 [ata_sff/1]
root        30     2  0 Jul20 ?        00:00:00 [ksuspend_usbd]
root        31     2  0 Jul20 ?        00:00:00 [khubd]
root        32     2  0 Jul20 ?        00:00:00 [kseriod]
root        33     2  0 Jul20 ?        00:00:00 [md/0]
root        34     2  0 Jul20 ?        00:00:00 [md/1]
root        35     2  0 Jul20 ?        00:00:00 [md_misc/0]
root        36     2  0 Jul20 ?        00:00:00 [md_misc/1]
root        37     2  0 Jul20 ?        00:00:00 [linkwatch]
root        39     2  0 Jul20 ?        00:00:00 [khungtaskd]
root        40     2  0 Jul20 ?        00:00:00 [kswapd0]
root        41     2  0 Jul20 ?        00:00:00 [ksmd]
root        42     2  0 Jul20 ?        00:00:03 [khugepaged]
root        43     2  0 Jul20 ?        00:00:00 [aio/0]
root        44     2  0 Jul20 ?        00:00:00 [aio/1]
root        45     2  0 Jul20 ?        00:00:00 [crypto/0]
root        46     2  0 Jul20 ?        00:00:00 [crypto/1]
root        54     2  0 Jul20 ?        00:00:00 [kthrotld/0]
root        55     2  0 Jul20 ?        00:00:00 [kthrotld/1]
root        56     2  0 Jul20 ?        00:00:00 [pciehpd]
root        58     2  0 Jul20 ?        00:00:00 [kpsmoused]
root        59     2  0 Jul20 ?        00:00:00 [usbhid_resumer]
root        60     2  0 Jul20 ?        00:00:00 [deferwq]
root        92     2  0 Jul20 ?        00:00:00 [kdmremove]
root        93     2  0 Jul20 ?        00:00:00 [kstriped]
root       177     2  0 Jul20 ?        00:00:13 [mpt_poll_0]
root       178     2  0 Jul20 ?        00:00:00 [mpt/0]
root       179     2  0 Jul20 ?        00:00:00 [scsi_eh_0]
root       183     2  0 Jul20 ?        00:00:00 [scsi_eh_1]
root       184     2  0 Jul20 ?        00:00:00 [scsi_eh_2]
root       315     2  0 Jul20 ?        00:00:00 [kdmflush]
root       317     2  0 Jul20 ?        00:00:00 [kdmflush]
root       334     2  0 Jul20 ?        00:00:45 [jbd2/dm-0-8]
root       335     2  0 Jul20 ?        00:00:00 [ext4-dio-unwrit]
root       424     1  0 Jul20 ?        00:00:00 /sbin/udevd -d
root       613     2  0 Jul20 ?        00:00:12 [vmmemctl]
root       726   424  0 Jul20 ?        00:00:00 /sbin/udevd -d
root       759     2  0 Jul20 ?        00:00:00 [jbd2/sda1-8]
root       760     2  0 Jul20 ?        00:00:00 [ext4-dio-unwrit]
root       803     2  0 Jul20 ?        00:00:02 [kauditd]
root       978     2  0 Jul20 ?        00:00:18 [flush-253:0]
root      1187     1  0 Jul20 ?        00:09:03 /usr/sbin/vmtoolsd
root      1215     1  0 Jul20 ?        00:00:06 auditd
root      1240     1  0 Jul20 ?        00:00:00 /sbin/portreserve
root      1249     1  0 Jul20 ?        00:00:09 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
root      1300     1  0 Jul20 ?        00:02:14 irqbalance --pid=/var/run/irqbalance.pid
rpc       1316     1  0 Jul20 ?        00:00:00 rpcbind
root      1331     1  0 Jul20 ?        00:01:42 /usr/sbin/sssd -f -D
root      1332  1331  0 Jul20 ?        00:01:13 /usr/libexec/sssd/sssd_be --domain modern.local --uid 0 --gid 0 --debug-to-files
root      1333  1331  0 Jul20 ?        00:03:14 /usr/libexec/sssd/sssd_nss --uid 0 --gid 0 --debug-to-files
root      1334  1331  0 Jul20 ?        00:00:15 /usr/libexec/sssd/sssd_sudo --uid 0 --gid 0 --debug-to-files
root      1335  1331  0 Jul20 ?        00:00:19 /usr/libexec/sssd/sssd_pam --uid 0 --gid 0 --debug-to-files
root      1336  1331  0 Jul20 ?        00:00:06 /usr/libexec/sssd/sssd_ssh --uid 0 --gid 0 --debug-to-files
root      1337  1331  0 Jul20 ?        00:00:06 /usr/libexec/sssd/sssd_pac --uid 0 --gid 0 --debug-to-files
dbus      1437     1  0 Jul20 ?        00:00:00 dbus-daemon --system
68        1453     1  0 Jul20 ?        00:00:03 hald
root      1454  1453  0 Jul20 ?        00:00:00 hald-runner
root      1486  1454  0 Jul20 ?        00:00:00 hald-addon-input: Listening on /dev/input/event2 /dev/input/event0
68        1496  1454  0 Jul20 ?        00:00:13 /usr/libexec/hald-addon-acpi
root      1532     1  0 Jul20 ?        00:00:17 /opt/storix/bin/lighttpd -f /storix/config/sthttpd.conf
root      1561     1  0 Jul20 ?        00:33:57 /opt/storix/tcl/bin/tcl /opt/storix/bin/stqdaemon
root      1653     1  0 Jul20 ?        00:00:00 /usr/sbin/sshd
ntp       1671     1  0 Jul20 ?        00:00:31 ntpd -x -u ntp:ntp -p /var/run/ntpd.pid
root      1791     1  0 Jul28 ?        00:00:06 /usr/sbin/httpd
root      1847     1  0 Jul20 ?        00:00:20 sendmail: accepting connections
smmsp     1856     1  0 Jul20 ?        00:00:00 sendmail: Queue runner@01:00:00 for /var/spool/clientmqueue
root      1880     1  0 Jul20 ?        00:00:00 /usr/sbin/abrtd
root      1888     1  0 Jul20 ?        00:00:04 abrt-dump-oops -d /var/spool/abrt -rwx /var/log/messages
root      1911     1  0 Jul20 ?        00:00:06 crond
root      1963     1  0 Jul20 ?        00:29:09 /usr/local/tripwire/te/agent/bin/../sup/rtm/tesvc -port 1169
root      1976     1  0 Jul20 ?        00:00:00 /usr/sbin/atd
root      1996     1  0 Jul20 ?        00:03:32 ./wrapper ./agent.conf wrapper.pidfile=../tmp/teagent.pid wrapper.daemonize=TRUE
root      1997  1996  0 Jul20 ?        00:10:33 /usr/local/tripwire/te/agent/jre/bin/java -da -server -Dtw.server=false -Djava.security.manager=com.tripwire.kernel.ext.security.TripwireSecurityManager -Djava.security.properties=/usr/local/tripwire/te/agent/data/security/security.properties -Djava.se
root      2007     1  0 Jul20 ?        00:00:00 rhnsd
root      2016     1  0 Jul20 ?        00:00:00 /usr/bin/rhsmcertd
root      2078     1  0 Jul20 ?        00:00:00 /usr/sbin/oddjobd -p /var/run/oddjobd.pid -t 300
root      2101     1  0 Jul20 ?        00:00:00 /usr/sbin/certmonger -S -p /var/run/certmonger.pid
root      2109     1  0 Jul20 tty1     00:00:00 /sbin/mingetty /dev/tty1
root      2111     1  0 Jul20 tty2     00:00:00 /sbin/mingetty /dev/tty2
root      2113     1  0 Jul20 tty3     00:00:00 /sbin/mingetty /dev/tty3
root      2115     1  0 Jul20 tty4     00:00:00 /sbin/mingetty /dev/tty4
root      2117     1  0 Jul20 tty5     00:00:00 /sbin/mingetty /dev/tty5
root      2119     1  0 Jul20 tty6     00:00:00 /sbin/mingetty /dev/tty6
root      2121   424  0 Jul20 ?        00:00:00 /sbin/udevd -d
root      4085  1653  0 07:39 ?        00:00:00 sshd: rardhani [priv]
rardhani  4176  4085  0 07:40 ?        00:00:00 sshd: rardhani@pts/0
rardhani  4177  4176  0 07:40 pts/0    00:00:00 -bash
root      4214  4177  0 07:40 pts/0    00:00:00 sudo su -
root      4230  4214  0 07:40 pts/0    00:00:00 su -
root      4231  4230  0 07:40 pts/0    00:00:00 -bash
apache    4600  1791  0 07:41 ?        00:00:06 /usr/sbin/httpd
root      5402     2  0 Jul20 ?        00:00:00 [bluetooth]
apache    5418  1791  0 00:43 ?        00:00:08 /usr/sbin/httpd
apache    5658  1791  0 00:44 ?        00:00:08 /usr/sbin/httpd
apache   13291  1791  0 Jul31 ?        00:00:08 /usr/sbin/httpd
apache   13292  1791  0 Jul31 ?        00:00:08 /usr/sbin/httpd
apache   13293  1791  0 Jul31 ?        00:00:08 /usr/sbin/httpd
apache   13294  1791  0 Jul31 ?        00:00:08 /usr/sbin/httpd
apache   13295  1791  0 Jul31 ?        00:00:08 /usr/sbin/httpd
apache   13296  1791  0 Jul31 ?        00:00:08 /usr/sbin/httpd
apache   13297  1791  0 Jul31 ?        00:00:08 /usr/sbin/httpd
apache   13298  1791  0 Jul31 ?        00:00:08 /usr/sbin/httpd
root     14823  4231  0 10:36 pts/0    00:00:00 ps -ef --cols=300
root     17782     1  0 Jul27 ?        00:00:03 xinetd -stayalive -pidfile /var/run/xinetd.pid
nna      21718     1  0 08:50 ?        00:00:00 /usr/local/bin/nfcapd -I 11 -l /usr/local/nagiosna/var/ASA172.22.249.254/flows -p 9996 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/ASA172.22.249.254/9996.pid -D -e -w -z
nna      21720 21718  0 08:50 ?        00:00:00 /usr/local/bin/nfcapd -I 11 -l /usr/local/nagiosna/var/ASA172.22.249.254/flows -p 9996 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/ASA172.22.249.254/9996.pid -D -e -w -z
nna      21750     1  0 08:50 ?        00:00:00 /usr/local/bin/nfcapd -I 12 -l /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows -p 9995 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/NagiosFusionRCD83_98/9995.pid -D -e -w -z
nna      21752 21750  0 08:50 ?        00:00:00 /usr/local/bin/nfcapd -I 12 -l /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows -p 9995 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/NagiosFusionRCD83_98/9995.pid -D -e -w -z
nna      21786     1  0 08:50 ?        00:00:00 /usr/local/bin/nfcapd -I 14 -l /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows -p 9998 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/9998.pid -D -e -w -z
nna      21787 21786  0 08:50 ?        00:00:00 /usr/local/bin/nfcapd -I 14 -l /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows -p 9998 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/9998.pid -D -e -w -z
root     29812     1  0 Jul26 ?        00:00:00 /bin/sh /usr/bin/mysqld_safe --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock --pid-file=/var/run/mysqld/mysqld.pid --basedir=/usr --user=mysql
mysql    29914 29812  0 Jul26 ?        00:01:49 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --log-error=/var/log/mysqld.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/lib/mysql/mysql.sock
[b][u]ERROR: opening '/usr/local/nagiosna/var/ASA172.22.249.254/bandwidth.rrd': No such file or directory
ERROR: opening '/usr/local/nagiosna/var/NagiosFusionRCD83_98/bandwidth.rrd': No such file or directory[/u][/b]
[root@lussvpnagiosdb00 var]#
Try disabling the firewall and tripwire on the Network Analyzer system and see if that helps.
Then run the tcpdump command and see if those devices are sending flow data. Without receiving data, the graphs will not populate with data.
Login to the NA server and run the following to create the blank bandwidth.rrd files.
su - nna
/usr/local/nagiosna/bin/initialize_source.py --directory /usr/local/nagiosna/var/ASA172.22.249.254 --port 9996
/usr/local/nagiosna/bin/initialize_source.py --directory /usr/local/nagiosna/var/NagiosFusionRCD83_98 --port 9995
/usr/local/nagiosna/bin/initialize_source.py --directory /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8 --port 9998
raamardhani7
su - nna
Hi Tom,
I am not sure on how to disable tripwire and firewall, could u please help me here. thanks.
[root@lussvpnagiosdb00 ~]# tcpdump -vv host 10.10.130.8
^C
0 packets captured
[root@lussvpnagiosdb00 ~]# ps -ef | grep -i tripwire
root      1963     1  0 Jul20 ?        00:29:24 /usr/local/tripwire/te/agent/bin/../sup/rtm/tesvc -port 1169
root      1997  1996  0 Jul20 ?        00:10:37 /usr/local/tripwire/te/agent/jre/bin/java -da -server -Dtw.server=false -Djava.security.manager=com.tripwire.kernel.ext.security.TripwireSecurityManager -Djava.security.properties=/usr/local/tripwire/te/agent/data/security/security.properties -Djava.security.policy==/usr/local/tripwire/te/agent/data/security/jaas.policy -Dfoo=bar -Djava.io.tmpdir=/usr/local/tripwire/te/agent/tmp -Dsun.rmi.dgc.server.gcInterval=3600000 -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.checkInterval=1800000 -Djava.awt.headless=true -Dtw.home=/usr/local/tripwire/te/agent -Djava.rmi.server.useCodebaseOnly=true -Xms5m -Xmx256m -Djava.library.path=../lib -classpath ../lib/tw-launcher.jar:../lib/ext/tw-ext.jar:../lib/test-agent.jar:../jre/lib/jce.jar:../jre/lib/rt.jar:../jre/lib/resources.jar:../data/config:../lib/ext/te-rmi-provider.jar -Dwrapper.key=LU3Rsouv3aaWwqxieUgCCKuo_OvVXoOb -Dwrapper.port=32000 -Dwrapper.jvm.port.min=31000 -Dwrapper.jvm.port.max=31999 -Dwrapper.disable_console_input=TRUE -Dwrapper.pid=1996 -Dwrapper.use_system_time=TRUE -Dwrapper.version=3.4.1-st -Dwrapper.native_library=wrapper -Dwrapper.service=TRUE -Dwrapper.disable_shutdown_hook=TRUE -Dwrapper.cpu.timeout=10 -Dwrapper.jvmid=1 com.tripwire.space.bootstrap.BootstrapLauncher
root     13975 11984  0 12:44 pts/0    00:00:00 grep -i tripwire
tcpdump -vv host 172.22.249.254
12:51:41.598165 IP (tos 0x0, ttl 252, id 63021, offset 0, flags [none], proto UDP (17), length 1488)
    172.22.249.254.12354 > lussvpnagiosdb00.fossil.com.palace-5: [udp sum ok] UDP, length 1460
12:51:42.016072 IP (tos 0x0, ttl 252, id 39521, offset 0, flags [none], proto UDP (17), length 1456)
    172.22.249.254.12354 > lussvpnagiosdb00.fossil.com.palace-5: [udp sum ok] UDP, length 1428
12:51:42.172252 IP (tos 0x0, ttl 252, id 52126, offset 0, flags [none], proto UDP (17), length 1400)
    172.22.249.254.12354 > lussvpnagiosdb00.fossil.com.palace-5: [udp sum ok] UDP, length 1372
12:51:42.442224 IP (tos 0x0, ttl 252, id 45903, offset 0, flags [none], proto UDP (17), length 1472)
    172.22.249.254.12354 > lussvpnagiosdb00.fossil.com.palace-5: [udp sum ok] UDP, length 1444
12:51:42.885009 IP (tos 0x0, ttl 252, id 36346, offset 0, flags [none], proto UDP (17), length 1452)
    172.22.249.254.12354 > lussvpnagiosdb00.fossil.com.palace-5: [udp sum ok] UDP, length 1424
12:51:44.203934 IP (tos 0x0, ttl 252, id 59334, offset 0, flags [none], proto UDP (17), length 1444)
    172.22.249.254.12354 > lussvpnagiosdb00.fossil.com.palace-5: [udp sum ok] UDP, length 1416
12:51:46.216887 IP (tos 0x0, ttl 252, id 65066, offset 0, flags [none], proto UDP (17), length 1480)
    172.22.249.254.12354 > lussvpnagiosdb00.fossil.com.palace-5: [udp sum ok] UDP, length 1452
To stop Tripwire, you should talk to your admin but to stop iptables, you would run the following
service iptables stop
Can you run the following and post the output so I can check and see if the bandwidth.rrd files were created?
ls -lR /usr/local/nagiosna/var/
raamardhani7
tgriep wrote:To stop Tripwire, you should talk to your admin but to stop iptables, you would run the following
Hi Tom,
For tripwire, i ll speak to our Linux admin and see if he can help us here.
For the IP tables part, u want me to restart that?
/usr/local/nagiosna/var/:
total 6100
drwxr-sr-x+ 3 nna nnacmd    4096 Aug  1 12:41 ASA172.22.249.254
-rwxr-xr-x+ 1 nna nnacmd  945347 Aug  1 13:05 backend.log
-rwxr-xr-x+ 1 nna nnacmd 1048533 Jul 29 07:45 backend.log.1
-rwxr-xr-x+ 1 nna nnacmd 1048545 Jul 25 15:35 backend.log.2
-rwxr-xr-x+ 1 nna nnacmd 1048542 Jul 21 14:05 backend.log.3
-rwxr-xr-x+ 1 nna nnacmd 1048501 Jun 26 05:10 backend.log.4
-rwxr-xr-x+ 1 nna nnacmd 1048543 Jun 18 01:40 backend.log.5
-rwxr-xr-x+ 1 nna nnacmd     499 Aug  1 13:08 cmdsubsys.log
drwxr-sr-x+ 3 nna nnacmd    4096 Aug  1 12:41 NagiosFusionRCD83_98
drwxr-sr-x+ 3 nna nnacmd    4096 Aug  1 12:41 VPN_Firewall_10_10_130_8
/usr/local/nagiosna/var/ASA172.22.249.254:
total 76
-rw-r--r--+ 1 nna nnacmd     6 Aug  1 12:41 9996.pid
drwxr-sr-x+ 2 nna nnacmd 69632 Aug  1 13:05 flows
/usr/local/nagiosna/var/ASA172.22.249.254/flows:
total 105092
-rwxr-xr-x+ 1 nna nnacmd   6379 Jul 24 15:10 nfcapd.201607241505
-rwxr-xr-x+ 1 nna nnacmd   5485 Jul 24 15:15 nfcapd.201607241510
-rwxr-xr-x+ 1 nna nnacmd   5456 Jul 24 15:20 nfcapd.201607241515
-rwxr-xr-x+ 1 nna nnacmd   7181 Jul 24 15:25 nfcapd.201607241520
-rwxr-xr-x+ 1 nna nnacmd   6190 Jul 24 15:30 nfcapd.201607241525
-rwxr-xr-x+ 1 nna nnacmd   5448 Jul 24 15:35 nfcapd.201607241530
-rwxr-xr-x+ 1 nna nnacmd   7769 Jul 24 15:40 nfcapd.201607241535
-rwxr-xr-x+ 1 nna nnacmd  13901 Jul 24 15:45 nfcapd.201607241540
-rwxr-xr-x+ 1 nna nnacmd   7533 Jul 24 15:50 nfcapd.201607241545
-rwxr-xr-x+ 1 nna nnacmd   6581 Jul 24 15:55 nfcapd.20160724155
-rwxr-xr-x+ 1 nna nnacmd   6409 Jul 24 16:00 nfcapd.201607241555
-rwxr-xr-x+ 1 nna nnacmd   5801 Jul 24 16:05 nfcapd.201607241600
-rwxr-xr-x+ 1 nna nnacmd   5505 Jul 24 16:10 nfcapd.201607241605
-rwxr-xr-x+ 1 nna nnacmd   4909 Jul 24 16:15 nfcapd.201607241610
-rwxr-xr-x+ 1 nna nnacmd   7589 Jul 24 16:20 nfcapd.201607241615
-rwxr-xr-x+ 1 nna nnacmd   8381 Jul 24 16:25 nfcapd.201607241620
-rwxr-xr-x+ 1 nna nnacmd   7382 Jul 24 16:30 nfcapd.201607241625
-rwxr-xr-x+ 1 nna nnacmd   5546 Jul 24 16:35 nfcapd.201607241630
-rwxr-xr-x+ 1 nna nnacmd   8749 Jul 24 16:40 nfcapd.201607241635
-rwxr-xr-x+ 1 nna nnacmd  12715 Jul 24 16:45 nfcapd.201607241640
-rwxr-xr-x+ 1 nna nnacmd   7395 Jul 24 16:50 nfcapd.201607241645
-rwxr-xr-x+ 1 nna nnacmd   6637 Jul 24 16:55 nfcapd.201607241650
-rwxr-xr-x+ 1 nna nnacmd   4990 Jul 24 17:00 nfcapd.201607241655
-rwxr-xr-x+ 1 nna nnacmd   6376 Jul 24 20:00 nfcapd.201607241955
-rwxr-xr-x+ 1 nna nnacmd   5899 Jul 24 20:05 nfcapd.201607242000
-rwxr-xr-x+ 1 nna nnacmd   7272 Jul 24 20:10 nfcapd.201607242005
-rwxr-xr-x+ 1 nna nnacmd   6188 Jul 24 20:15 nfcapd.201607242010
-rwxr-xr-x+ 1 nna nnacmd   6025 Jul 24 20:20 nfcapd.201607242015
-rwxr-xr-x+ 1 nna nnacmd   7390 Jul 24 20:25 nfcapd.201607242020
-rwxr-xr-x+ 1 nna nnacmd   5383 Jul 24 20:30 nfcapd.201607242025
-rwxr-xr-x+ 1 nna nnacmd   6259 Jul 24 20:35 nfcapd.201607242030
/usr/local/nagiosna/var/NagiosFusionRCD83_98:
total 108
-rw-r--r--+ 1 nna nnacmd      6 Aug  1 12:41 9995.pid
drwxr-sr-x+ 2 nna nnacmd 102400 Aug  1 13:05 flows
-rwxr-xr-x+ 1 nna nnacmd      0 Jul 28 18:30 test
/usr/local/nagiosna/var/NagiosFusionRCD83_98/flows:
total 10776
-rwxr-xr-x+ 1 nna nnacmd  3854 Jul 24 15:45 nfcapd.201607241540
-rwxr-xr-x+ 1 nna nnacmd  2960 Jul 24 15:50 nfcapd.201607241545
-rwxr-xr-x+ 1 nna nnacmd  4428 Jul 24 15:55 nfcapd.201607241550
-rwxr-xr-x+ 1 nna nnacmd  3205 Jul 24 16:00 nfcapd.201607241555
-rwxr-xr-x+ 1 nna nnacmd  3526 Jul 24 16:05 nfcapd.201607241600
-rwxr-xr-x+ 1 nna nnacmd  4280 Jul 24 16:10 nfcapd.201607241605
-rwxr-xr-x+ 1 nna nnacmd  3532 Jul 24 16:15 nfcapd.201607241610
-rwxr-xr-x+ 1 nna nnacmd  3827 Jul 24 16:20 nfcapd.201607241615
-rwxr-xr-x+ 1 nna nnacmd  3488 Jul 24 16:25 nfcapd.201607241620
-rwxr-xr-x+ 1 nna nnacmd  3984 Aug  1 05:40 nfcapd.201608010535
-rwxr-xr-x+ 1 nna nnacmd  3307 Aug  1 05:45 nfcapd.201608010540
-rwxr-xr-x+ 1 nna nnacmd  3707 Aug  1 05:50 nfcapd.201608010545
-rwxr-xr-x+ 1 nna nnacmd  3993 Aug  1 05:55 nfcapd.201608010550
-rwxr-xr-x+ 1 nna nnacmd  3048 Aug  1 06:00 nfcapd.201608010555
-rwxr-xr-x+ 1 nna nnacmd  4137 Aug  1 06:05 nfcapd.201608010600
-rwxr-xr-x+ 1 nna nnacmd  3926 Aug  1 06:10 nfcapd.201608010605
-rwxr-xr-x+ 1 nna nnacmd  4465 Aug  1 06:15 nfcapd.201608010610
-rwxr-xr-x+ 1 nna nnacmd  3212 Aug  1 06:20 nfcapd.201608010615
-rwxr-xr-x+ 1 nna nnacmd  3819 Aug  1 06:25 nfcapd.201608010620
-rwxr-xr-x+ 1 nna nnacmd  3411 Aug  1 06:30 nfcapd.201608010625
-rwxr-xr-x+ 1 nna nnacmd  3411 Aug  1 06:35 nfcapd.201608010630
-rwxr-xr-x+ 1 nna nnacmd  4531 Aug  1 06:40 nfcapd.201608010635
-rwxr-xr-x+ 1 nna nnacmd  3338 Aug  1 06:45 nfcapd.201608010640
-rwxr-xr-x+ 1 nna nnacmd  3676 Aug  1 06:50 nfcapd.201608010645
/usr/local/nagiosna/var/VPN_Firewall_10_10_130_8:
total 20
-rw-r--r--+ 1 nna nnacmd     6 Aug  1 12:41 9998.pid
drwxr-sr-x+ 2 nna nnacmd 16384 Aug  1 13:05 flows
/usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows:
total 1100-rw-r--r--+ 1 nna nnacmd 622 Aug  1 10:25 nfcapd.201608011020
-rw-r--r--+ 1 nna nnacmd 627 Aug  1 10:30 nfcapd.201608011025
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 10:35 nfcapd.201608011030
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 10:40 nfcapd.201608011035
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 10:45 nfcapd.201608011040
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 10:50 nfcapd.201608011045
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 10:55 nfcapd.201608011050
-rw-r--r--+ 1 nna nnacmd 627 Aug  1 11:00 nfcapd.201608011055
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:05 nfcapd.201608011100
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:10 nfcapd.201608011105
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:15 nfcapd.201608011110
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:20 nfcapd.201608011115
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:25 nfcapd.201608011120
-rw-r--r--+ 1 nna nnacmd 627 Aug  1 11:30 nfcapd.201608011125
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:35 nfcapd.201608011130
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:40 nfcapd.201608011135
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:45 nfcapd.201608011140
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:50 nfcapd.201608011145
-rw-r--r--+ 1 nna nnacmd 622 Aug  1 11:55 nfcapd.201608011150
-rw-r--r--+ 1 nna nnacmd 627 Aug  1 12:00 nfcapd.201608011155
-rwxr-xr-x+ 1 nna nnacmd 622 Jul 31 14:20 nfcapd.201607311415
-rwxr-xr-x+ 1 nna nnacmd 622 Jul 31 14:25 nfcapd.201607311420
-rwxr-xr-x+ 1 nna nnacmd 627 Jul 31 14:30 nfcapd.201607311425
I just wanted to stop the firewall until the issue is resolved.
It looks like the bandwidth files were not created, did you run the following on the server?
su - nna
Can you run them again and post the output.
Also, run this on the server and post the output here.
raamardhani7
tgriep wrote:I just wanted to stop the firewall until the issue is resolved.
su - nna
Hi Tom,
I've ran those commands, will get that tripwire and security disabled.
[nna@lussvpnagiosdb00 ~]$ su - nna
[nna@lussvpnagiosdb00 ~]$ /usr/local/nagiosna/bin/initialize_source.py --directory /usr/local/nagiosna/var/ASA172.22.249.254 --port 9996
sudo /sbin/iptables -I INPUT -p udp -j ACCEPT --dport 9996
Saving...
iptables: Saving firewall rules to /etc/sysconfig/iptables:[  OK  ]
[nna@lussvpnagiosdb00 ~]$ /usr/local/nagiosna/bin/initialize_source.py --directory /usr/local/nagiosna/var/NagiosFusionRCD83_98 --port 9995
sudo /sbin/iptables -I INPUT -p udp -j ACCEPT --dport 9995
Saving...
[nna@lussvpnagiosdb00 ~]$ /usr/local/nagiosna/bin/initialize_source.py --directory /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8 --port 9998
sudo /sbin/iptables -I INPUT -p udp -j ACCEPT --dport 9998
Saving...
2016-08-01 20:20:03 INFO : Ran checks successfully
2016-08-01 20:20:03 INFO : Successfully reaped nfcapd file.
2016-08-01 20:20:03 INFO : Parsing data for the source id: 11
2016-08-01 20:20:03 DEBUG : Arguments: /usr/local/nagiosna/var/ASA172.22.249.254/flows, nfcapd.201608012015, 11
2016-08-01 20:20:03 DEBUG : Running checks...
2016-08-01 20:20:03 DEBUG : Getting relevant checks for source id: 11
2016-08-01 20:20:03 DEBUG : Checks found: ()
2016-08-01 20:20:10 INFO : Parsing data for the source id: 14
2016-08-01 20:20:10 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608012015, 14
2016-08-01 20:20:10 DEBUG : Running checks...
2016-08-01 20:20:10 DEBUG : Getting relevant checks for source id: 14
2016-08-01 20:20:10 DEBUG : Checks found: ()
2016-08-01 20:20:10 INFO : Ran checks successfully
2016-08-01 20:20:10 INFO : Successfully reaped nfcapd file.
2016-08-01 20:25:01 INFO : Parsing data for the source id: 11
2016-08-01 20:25:01 DEBUG : Arguments: /usr/local/nagiosna/var/ASA172.22.249.254/flows, nfcapd.201608012020, 11
2016-08-01 20:25:01 DEBUG : Running checks...
2016-08-01 20:25:01 DEBUG : Getting relevant checks for source id: 11
2016-08-01 20:25:01 DEBUG : Checks found: ()
2016-08-01 20:25:01 INFO : Ran checks successfully
2016-08-01 20:25:01 INFO : Successfully reaped nfcapd file.
2016-08-01 20:25:03 INFO : Parsing data for the source id: 12
2016-08-01 20:25:03 DEBUG : Arguments: /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows, nfcapd.201608012020, 12
2016-08-01 20:25:03 DEBUG : Running checks...
2016-08-01 20:25:03 DEBUG : Getting relevant checks for source id: 12
2016-08-01 20:25:03 DEBUG : Checks found: ()
2016-08-01 20:25:03 INFO : Ran checks successfully
2016-08-01 20:25:03 INFO : Successfully reaped nfcapd file.
2016-08-01 20:25:10 INFO : Parsing data for the source id: 14
2016-08-01 20:25:10 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608012020, 14
2016-08-01 20:25:10 DEBUG : Running checks...
2016-08-01 20:25:10 DEBUG : Getting relevant checks for source id: 14
2016-08-01 20:25:10 DEBUG : Checks found: ()
2016-08-01 20:25:10 INFO : Ran checks successfully
2016-08-01 20:25:10 INFO : Successfully reaped nfcapd file.
2016-08-01 20:30:04 INFO : Parsing data for the source id: 11
2016-08-01 20:30:04 DEBUG : Arguments: /usr/local/nagiosna/var/ASA172.22.249.254/flows, nfcapd.201608012025, 11
2016-08-01 20:30:04 DEBUG : Running checks...
2016-08-01 20:30:04 DEBUG : Getting relevant checks for source id: 11
2016-08-01 20:30:04 DEBUG : Checks found: ()
2016-08-01 20:30:04 INFO : Ran checks successfully
2016-08-01 20:30:04 INFO : Successfully reaped nfcapd file.
2016-08-01 20:30:10 INFO : Parsing data for the source id: 14
2016-08-01 20:30:10 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608012025, 14
2016-08-01 20:30:11 DEBUG : Running checks...
2016-08-01 20:30:11 DEBUG : Getting relevant checks for source id: 14
2016-08-01 20:30:11 DEBUG : Checks found: ()
2016-08-01 20:30:11 INFO : Ran checks successfully
2016-08-01 20:30:11 INFO : Successfully reaped nfcapd file.
2016-08-01 20:30:11 INFO : Parsing data for the source id: 12
2016-08-01 20:30:11 DEBUG : Arguments: /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows, nfcapd.201608012025, 12
2016-08-01 20:30:11 DEBUG : Getting relevant checks for source id: 12
2016-08-01 20:35:02 INFO : Parsing data for the source id: 11
2016-08-01 20:35:02 DEBUG : Arguments: /usr/local/nagiosna/var/ASA172.22.249.254/flows, nfcapd.201608012030, 11
2016-08-01 20:35:02 DEBUG : Running checks...
2016-08-01 20:35:02 DEBUG : Getting relevant checks for source id: 11
2016-08-01 20:35:02 DEBUG : Checks found: ()
2016-08-01 20:35:02 INFO : Ran checks successfully
2016-08-01 20:35:02 INFO : Successfully reaped nfcapd file.
2016-08-01 20:35:08 INFO : Parsing data for the source id: 12
2016-08-01 20:35:08 DEBUG : Arguments: /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows, nfcapd.201608012030, 12
2016-08-01 20:35:08 DEBUG : Running checks...
2016-08-01 20:35:08 DEBUG : Getting relevant checks for source id: 12
2016-08-01 20:35:08 DEBUG : Checks found: ()
2016-08-01 20:35:08 INFO : Ran checks successfully
2016-08-01 20:35:08 INFO : Successfully reaped nfcapd file.
2016-08-01 20:35:10 INFO : Parsing data for the source id: 14
2016-08-01 20:35:10 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608012030, 14
2016-08-01 20:35:10 DEBUG : Running checks...
2016-08-01 20:35:10 DEBUG : Getting relevant checks for source id: 14
2016-08-01 20:35:10 DEBUG : Checks found: ()
2016-08-01 20:35:10 INFO : Ran checks successfully
2016-08-01 20:35:10 INFO : Successfully reaped nfcapd file.
2016-08-01 20:38:43 INFO : Parsing data for the source id: 11
2016-08-01 20:38:43 DEBUG : Arguments: /usr/local/nagiosna/var/ASA172.22.249.254/flows, nfcapd.201608012035, 11
2016-08-01 20:38:43 INFO : Parsing data for the source id: 12
2016-08-01 20:38:43 DEBUG : Arguments: /usr/local/nagiosna/var/NagiosFusionRCD83_98/flows, nfcapd.201608012035, 12
2016-08-01 20:38:43 DEBUG : Running checks...
2016-08-01 20:38:43 DEBUG : Getting relevant checks for source id: 11
2016-08-01 20:38:43 DEBUG : Checks found: ()
2016-08-01 20:38:43 INFO : Ran checks successfully
2016-08-01 20:38:43 INFO : Successfully reaped nfcapd file.
2016-08-01 20:38:43 DEBUG : Getting relevant checks for source id: 12
2016-08-01 20:38:43 INFO : Parsing data for the source id: 14
2016-08-01 20:38:43 DEBUG : Arguments: /usr/local/nagiosna/var/VPN_Firewall_10_10_130_8/flows, nfcapd.201608012035, 14
2016-08-01 20:38:43 DEBUG : Getting relevant checks for source id: 14
tail -20 /var/log/httpd/error_log
Can you login to the NNA server and run the following as root and post the output?
find /usr/local -name py_rrd*
ls -l /usr/local
ls -l /usr/local/nagiosna/var/
yum list installed |grep rrdtool
