elasticsearch is crashing
_asp_
Post by _asp_ »
We have a problem with elastic search in our productive environment. Until the sales / support staff is not granting us the permission to access the customer support, i have to post here.
Today our logserver instance has crashed twice today. With crashed I mean it is not responding any longer.
After stopping and starting both services (logstash and elasticsearch) it is running again for some hours.
After stopping elasticsearch I got following from os:
sudo service elasticsearch status
-> elasticsearch dead but subsys locked
in logstash logs i can find following errors:
{:timestamp=>"2016-08-02T12:41:57.888000+0200", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2016-08-02T12:41:57.888000+0200", :message=>"Failed to flush outgoing items", :outgoing_count=>987, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:606)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:112)", "org.jruby.RubyKernel.loop(org/jruby/RubyKernel.java:1511)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:110)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2016-08-02T12:41:58.902000+0200", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2016-08-02T12:41:58.902000+0200", :message=>"Failed to flush outgoing items", :outgoing_count=>987, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:606)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:112)", "org.jruby.RubyKernel.loop(org/jruby/RubyKernel.java:1511)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:110)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2016-08-02T12:42:00.885000+0200", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
The only change we made is adding more complex parsing for one of our logfile with lot of ruby code resulting in more parsed / calculated fields.
How can I check if there if memory gets low / if elasticsearch has an outOfMemory error?
What do you need for helping?
hsmith
Agent Smith
Re: elasticsearch is crashing
Post by hsmith »
Anything in /var/log/messages from the same time as the crash?
What are the resources dedicated to this machine?
Former Nagios Employee.
me.
_asp_
Post by _asp_ »
resources are quite small. 2vCPU and 4GB Ram
nope, nothing found in /var/log/messages around the time where we have the errors in logstash shown below in thread starting post.
in leasticsearchlog found something like that with different ids
[2016-08-02 12:38:48,989][DEBUG][action.search.type       ] [f12d79cf-a699-42b8-b6c2-47d36407ac87] [376148] Failed to execute fetch phase
org.elasticsearch.search.SearchContextMissingException: No search context found for id [376148]
        at org.elasticsearch.search.SearchService.findContext(SearchService.java:525)
        at org.elasticsearch.search.SearchService.executeFetchPhase(SearchService.java:495)
        at org.elasticsearch.search.action.SearchServiceTransportAction$17.call(SearchServiceTransportAction.java:452)
        at org.elasticsearch.search.action.SearchServiceTransportAction$17.call(SearchServiceTransportAction.java:449)
        at org.elasticsearch.search.action.SearchServiceTransportAction$23.run(SearchServiceTransportAction.java:559)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
        at java.lang.Thread.run(Thread.java:745)
but this also appears before and after the time of these logstash events.
hsmith
Agent Smith
Post by hsmith »
How much data per day of logs are you getting? 4GB could be problematic.
me.
_asp_
Post by _asp_ »
dont know the raw count.
logserver says primary index size per day is between 1.3 and 1.8 GB per day.
hsmith
Agent Smith
Post by hsmith »
Is the crashing consistently happening?
Can you increase your RAM to see if this stops it?
me.
Closing due to inactivity. Please let me know via PM if you would like this re-opened.
