i testing the Nagios Logserver and i have change the IP Address after install.
When i use the %url% in my Email-Template then is there my old IP in the link where can i find the %url% Variable or how can i fix it ?
I need the actually IP -Address in this %url%
greetings
Sven
Email-Template definition %url% variable
Re: Email-Template definition %url% variable
How long has it been since you changed the IP?
Former Nagios Employee.
me.
me.
I just tested this, and it's because your old IP is set in the Administration -> Global Settings -> Interface URL field. Adjust it here, and your alerts will then be updated.
Thx for this fast answer it works !
Did you need anything else, or are we good to close this thread?
me.
me.
Closing due to inactivity. Please let me know via PM if you would like this re-opened.
