Nagios 4.2.0 reload stop nagios (bug?)
briancolman
Post by briancolman »
Hi everyone,
Yesterday update my instalation of Nagios Core to 4.2.0, after that, when we use reload with the init script, this stop the Nagios, but stop in a way that cant be start again before make stop with the init script. :shock: No error on log, only the shutdown sequence
Some else have the same issue? :?:
Re: Nagios 4.2.0 reload stop nagios (bug?)
Can you run the following command to verify the configuration files and post the errors here?
/usr/local/nagios/bin/nagios -vv /usr/local/nagios/etc/nagios.cfg
Can you post how you are starting, reloading and stopping the nagios process and the output when you try doing that?
jpcozar
Post by jpcozar »
Same problem here after upgrading from Nagios Core 4.1.1 to Nagios 4.2.0
Nagios is running nicely:
ps -ef|grep nagios
nagios   10074     1  0 ago08 ?        00:04:17 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   10075 10074  0 ago08 ?        00:00:23 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   10076 10074  0 ago08 ?        00:00:23 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   10077 10074  0 ago08 ?        00:00:23 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   10078 10074  0 ago08 ?        00:00:23 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   10079 10074  0 ago08 ?        00:00:20 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   10080 10074  0 ago08 ?        00:00:23 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
Init script says it too:
sudo service nagios status
nagios (pid 10074) is running...
Now I do a change in configuration of a *.cfg file and verify configuration is ok:
Nagios Core 4.2.0
Last Modified: 08-01-2016
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config file '/usr/local/nagios/etc/objects/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/templates.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/windows_CEMCOR.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/windows_SAE.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/switch_RED_ES_CEICE.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/switch_RED_ES_SAE.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/switch_CEMCOR.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/switch_SAE.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/switch_CEIC.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/accesspoints.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/router.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/ups.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/nas.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/terminal.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/windows-virtuales.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/windows-gefoc.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/vmware.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/linux.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/libreria.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/qmatic_SAE.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/SAC_NemoQ.cfg'...
Checking objects...
	Checked 738 services.
	Checked 174 hosts.
	Checked 27 host groups.
	Checked 7 service groups.
	Checked 2 contacts.
	Checked 1 contact groups.
	Checked 69 commands.
	Checked 6 time periods.
	Checked 0 host escalations.
	Checked 174 hosts
	Checked 0 host dependencies
	Checked 6 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
So I reload nagios:
 sudo service nagios reload
Running configuration check...
Reloading nagios configuration...
done
It seems everything is ok but if I check it:
nagios is not running
And no PID associate...nagios has been killed and I have to start it manually again :cry:
ps -ef|grep nagios
jpcozar   4477 29264  0 11:33 pts/5    00:00:00 grep --color=auto nagios
What's wrong with nagios reloading in 4..2.0 version ? Thank you in advance
Can you login to the Nagios server as root, run the following commands and post the output?
ls -l /usr/local/nagios/sbin
ls -l /usr/local/nagios/var
head -n 1 /usr/local/nagios/var/nagios.lock
Also, post the /etc/init.d/nagios file here so we can view it.
Post by Box293 »
Did you also upgrade to the latest version of NDO? Core 4.2.0 won't load without this.
https://support.nagios.com/forum/viewto ... hilit=+ndo
jpcozar
Post by jpcozar »
Yes. Ndo was updated from 2.0.1 to 2.1.0. because Nagios 4.2.0 didnt run other way and it was clearly showed in nagios.log.
Now the problem is just with reloading....starting and stopping is working fine.
Indeed, today I just did a reload without doing any configuration change and nagios is stopped :-(
nagios.log only shows that:
[1470813111] Caught SIGSEGV, shutting down...
My OS is Ubuntu 14.04.5 LTS updated if it can helps.
jpcozar
Post by jpcozar »
tgriep wrote:Can you login to the Nagios server as root, run the following commands and post the output?
Here it is the info that was asked for:
total 5184
-rwxrwxr-x 1 nagios nagcmd 320616 ago  4 11:16 archivejson.cgi
-rwxrwxr-x 1 nagios nagcmd 306008 ago  4 11:16 avail.cgi
-rwxrwxr-x 1 nagios nagcmd 300336 ago  4 11:16 cmd.cgi
-rwxrwxr-x 1 nagios nagcmd 273160 ago  4 11:16 config.cgi
-rwxrwxr-x 1 nagios nagios  17272 ago  6  2010 downtime_sched.cgi
-rwxrwxr-x 1 nagios nagcmd 314168 ago  4 11:16 extinfo.cgi
-rwxrwxr-x 1 nagios nagcmd 265160 ago  4 11:16 histogram.cgi
-rwxrwxr-x 1 nagios nagcmd 244536 ago  4 11:16 history.cgi
-rwxrwxr-x 1 nagios nagcmd 244528 ago  4 11:16 notifications.cgi
-rwxrwxr-x 1 nagios nagcmd 322408 ago  4 11:16 objectjson.cgi
-rwxrwxr-x 1 nagios nagcmd 236296 ago  4 11:16 outages.cgi
-rwxrwxr-x 1 nagios nagcmd 240408 ago  4 11:16 showlog.cgi
-rwxrwxr-x 1 nagios nagcmd 314192 ago  4 11:16 status.cgi
-rwxrwxr-x 1 nagios nagcmd 316456 ago  4 11:16 statusjson.cgi
-rwxrwxr-x 1 nagios nagcmd 265216 ago  4 11:16 statusmap.cgi
-rwxrwxr-x 1 nagios nagcmd 256848 ago  4 11:16 statuswml.cgi
-rwxrwxr-x 1 nagios nagcmd 244528 ago  4 11:16 statuswrl.cgi
-rwxrwxr-x 1 nagios nagcmd 265056 ago  4 11:16 summary.cgi
-rwxrwxr-x 1 nagios nagcmd 256864 ago  4 11:16 tac.cgi
-rwxrwxr-x 1 nagios nagcmd 273352 ago  4 11:16 trends.cgi
total 8684
drwxrwxr-x 3 nagios nagcmd    106496 ago  8 23:59 archives
-rw-r--r-- 1 nagios nagios         0 ago 10 09:19 check_vmfs.err
-rw-r--r-- 1 nagios nagios       319 abr  9  2013 check_vmfs.std
-rw-r--r-- 1 nagios nagios      1834 jul 25  2014 configcheck17063
-rw-r--r-- 1 nagios nagios      1834 jul 25  2014 configcheck17403
-rw-r--r-- 1 nagios nagios      1470 jul 25  2014 configcheck22503
-rw-r--r-- 1 nagios nagios      1470 jul 25  2014 configcheck22557
-rw-r--r-- 1 nagios nagios      1470 jul 25  2014 configcheck23280
-rw-r--r-- 1 nagios nagios      1470 jul 25  2014 configcheck23327
-rw-r--r-- 1 nagios nagios      1470 jul 25  2014 configcheck28974
-rw-r--r-- 1 nagios nagios       255 ago 10 09:01 downtime.log
-rw-r--r-- 1 nagios nagcmd        34 ago 10 09:14 nagios.configtest
-rw-r--r-- 1 nagios nagcmd         6 ago 10 09:13 nagios.lock
-rw-r--r-- 1 nagios nagios    807797 ago 10 09:20 nagios.log
-rw-rw-r-- 1 nagios nagios   1130941 jul  2  2015 nagios.tmpHNaBt9
-rw-rw-r-- 1 nagios nagios   1140674 sep  7  2015 nagios.tmpHtGhGz
-rw-rw-r-- 1 nagios nagios   1312558 may  8  2015 nagios.tmpQKNwoj
-rw-r--r-- 1 nagios nagios         2 ago 10 08:25 ndo2db.lock
-rw-r--r-- 1 nagios nagios         0 ago 10 09:11 ndomod.tmp
srwxr-xr-x 1 nagios nagios         0 ago 10 08:25 ndo.sock
-rw-r--r-- 1 nagios nagios    912373 ago 10 09:13 objects.cache
-rw-r--r-- 1 nagios nagios    912373 ago 10 09:14 objects.precache
-rw------- 1 nagios nagcmd   1245882 ago 10 09:13 retention.dat
drwxrwsr-x 2 nagios www-data    4096 ago 10 09:16 rw
drwxr-xr-x 3 nagios nagios      4096 ago  5  2010 spool
-rw-rw-r-- 1 nagios nagios   1242172 ago 10 09:20 status.dat
]head -n 1 /usr/local/nagios/var/nagios.lock
11859
/etc/init.d/nagios
cat /etc/init.d/nagios
#!/bin/sh
# chkconfig: 345 99 01
# description: Nagios network monitor
# processname: nagios
# File : nagios
# Author : Jorge Sanchez Aymar ([email protected])
# Changelog :
# 1999-07-09 Karl DeBisschop <[email protected]>
#  - setup for autoconf
#  - add reload function
# 1999-08-06 Ethan Galstad <[email protected]>
#  - Added configuration info for use with RedHat's chkconfig tool
#    per Fran Boon's suggestion
# 1999-08-13 Jim Popovitch <[email protected]>
#  - added variable for nagios/var directory
#  - cd into nagios/var directory before creating tmp files on startup
# 1999-08-16 Ethan Galstad <[email protected]>
#  - Added test for rc.d directory as suggested by Karl DeBisschop
# 2000-07-23 Karl DeBisschop <[email protected]>
#  - Clean out redhat macros and other dependencies
# 2003-01-11 Ethan Galstad <[email protected]>
#  - Updated su syntax (Gary Miller)
# Description: Starts and stops the Nagios monitor
#              used to provide network services status.
### BEGIN INIT INFO
# Provides:		nagios
# Required-Start:	$local_fs $syslog $network
# Required-Stop:	$local_fs $syslog $network
# Default-Start:	2 3 4 5
# Default-Stop:		0 1 6
# Short-Description:	Starts and stops the Nagios monitoring server
# Description:		Starts and stops the Nagios monitoring server
### END INIT INFO
# Our install-time configuration.
prefix=/usr/local/nagios
exec_prefix=${prefix}
NagiosBin=${exec_prefix}/bin/nagios
NagiosCfgFile=${prefix}/etc/nagios.cfg
NagiosCfgtestFile=${prefix}/var/nagios.configtest
NagiosStatusFile=${prefix}/var/status.dat
NagiosRetentionFile=${prefix}/var/retention.dat
NagiosCommandFile=${prefix}/var/rw/nagios.cmd
NagiosVarDir=${prefix}/var
NagiosRunFile=${prefix}/var/nagios.lock
NagiosLockDir=/var/lock/subsys
NagiosLockFile=nagios
NagiosCGIDir=${exec_prefix}/sbin
NagiosUser=nagios
NagiosGroup=nagcmd
checkconfig="true"
# Source function library
# Some *nix do not have an rc.d directory, so do a test first
if [ -f /etc/rc.d/init.d/functions ]; then
	. /etc/rc.d/init.d/functions
elif [ -f /etc/init.d/functions ]; then
	. /etc/init.d/functions
elif [ -f /lib/lsb/init-functions ]; then
	. /lib/lsb/init-functions
fi
# Load any extra environment variables for Nagios and its plugins.
if test -f /etc/sysconfig/nagios; then
	. /etc/sysconfig/nagios
fi
# Automate addition of RAMDISK based on environment variables
USE_RAMDISK=${USE_RAMDISK:-0}
if test "$USE_RAMDISK" -ne 0 && test "$RAMDISK_SIZE"X != "X"; then
	ramdisk=`mount |grep "${RAMDISK_DIR} type tmpfs"`
	if [ "$ramdisk"X == "X" ]; then
		mkdir -p -m 0755 ${RAMDISK_DIR}
		mount -t tmpfs -o size=${RAMDISK_SIZE}m tmpfs ${RAMDISK_DIR}
		mkdir -p -m 0755 ${RAMDISK_DIR}/checkresults
		chown -R $NagiosUser:$NagiosGroup ${RAMDISK_DIR}
	fi
fi
check_config ()
	TMPFILE=$(mktemp /tmp/.configtest.XXXXXXXX)
	$NagiosBin -vp $NagiosCfgFile > "$TMPFILE"
	WARN=`grep ^"Total Warnings:" "$TMPFILE" |awk -F: '{print \$2}' |sed s/' '//g`
	ERR=`grep ^"Total Errors:" "$TMPFILE" |awk -F: '{print \$2}' |sed s/' '//g`
	if test "$WARN" = "0" && test "${ERR}" = "0"; then
		echo "OK - Configuration check verified" > $NagiosCfgtestFile
		chmod 0644 $NagiosCfgtestFile
		chown $NagiosUser:$NagiosGroup $NagiosCfgtestFile
		/bin/rm "$TMPFILE"
		return 0
	elif test "${ERR}" = "0"; then
		# Write the errors to a file we can have a script watching for.
		echo "WARNING: Warnings in config files - see log for details: $NagiosCfgtestFile" > $NagiosCfgtestFile
		egrep -i "(^warning|^error)" "$TMPFILE" >> $NagiosCfgtestFile
		/bin/rm "$TMPFILE"
		return 0
	else
		echo "ERROR: Errors in config files - see log for details: $NagiosCfgtestFile" > $NagiosCfgtestFile
		cat "$TMPFILE"
		exit 8
	fi
status_nagios ()
	if test -x $NagiosCGI/daemonchk.cgi; then
		if $NagiosCGI/daemonchk.cgi -l $NagiosRunFile > /dev/null 2>&1; then return 0; fi
	else
		if ps -p $NagiosPID > /dev/null 2>&1; then return 0; fi
	fi
	return 1
printstatus_nagios ()
	if status_nagios; then
		echo "nagios (pid $NagiosPID) is running..."
	else
		echo "nagios is not running"
	fi
killproc_nagios ()
	kill -s "$1" $NagiosPID
pid_nagios ()
	if test ! -f $NagiosRunFile; then
		echo "No lock file found in $NagiosRunFile"
		exit 1
	fi
	NagiosPID=`head -n 1 $NagiosRunFile`
# Check that nagios exists.
if [ ! -f $NagiosBin ]; then
    echo "Executable file $NagiosBin not found. Exiting."
    exit 1
fi
# Check that nagios.cfg exists.
if [ ! -f $NagiosCfgFile ]; then
    echo "Configuration file $NagiosCfgFile not found. Exiting."
    exit 1
fi
# See how we were called.
case "$1" in
	start)
		echo -n "Starting nagios:"
		if test "$checkconfig" = "true"; then
			check_config
			# check_config exits on configuration errors.
		fi
		if test -f $NagiosRunFile; then
				echo " another instance of nagios is already running."
				exit 0
			fi
		fi
		touch $NagiosVarDir/nagios.log $NagiosRetentionFile
		rm -f $NagiosCommandFile
		touch $NagiosRunFile
		chown $NagiosUser:$NagiosGroup $NagiosRunFile $NagiosVarDir/nagios.log $NagiosRetentionFile
		$NagiosBin -d $NagiosCfgFile
		if [ -d $NagiosLockDir ]; then touch $NagiosLockDir/$NagiosLockFile; fi
		echo " done."
	stop)
		echo -n "Stopping nagios:"
		pid_nagios
		killproc_nagios TERM
		# now we have to wait for nagios to exit and remove its
		# own NagiosRunFile, otherwise a following "start" could
		# happen, and then the exiting nagios will remove the
		# new NagiosRunFile, allowing multiple nagios daemons
		# to (sooner or later) run - John Sellens
		#echo -n 'Waiting for nagios to exit .'
		for i in {1..90}; do
			if status_nagios > /dev/null; then
				echo -n '.'
				sleep 1
			else
				break
			fi
		done
			echo ''
			echo 'Warning - nagios did not exit in a timely manner - Killing it!'
			killproc_nagios KILL
		else
			echo ' done.'
		fi
		rm -f $NagiosStatusFile $NagiosRunFile $NagiosLockDir/$NagiosLockFile $NagiosCommandFile
	status)
		pid_nagios
		printstatus_nagios
	checkconfig)
			printf "Running configuration check...\n"
			check_config
		fi
		if [ $? -eq 0 ]; then
			echo " OK."
		else
			echo " CONFIG ERROR!  Check your Nagios configuration."
			exit 1
		fi
	restart)
			check_config
		fi
		$0 stop
		$0 start
	reload|force-reload)
			check_config
		fi
			$0 start
		else
			pid_nagios
				printf "Reloading nagios configuration...\n"
				killproc_nagios HUP
				echo "done"
			else
				$0 stop
				$0 start
			fi
		fi
	configtest)
		echo "Usage: nagios {start|stop|restart|reload|force-reload|status|checkconfig|configtest}"
		exit 1
esac
# End of this script
Can you edit the /etc/init.d/nagios file and edit line 53 and change it from
to
NagiosLockDir=/usr/local/nagiosxi/var/subsys
Save the file out and post back the results.
jfrickson
Post by jfrickson »
I'm working on it, but it's a real sneaky issue. For now, just do restarts instead of reloads until I get it figured out.
jpcozar
Post by jpcozar »
tgriep wrote:Can you edit the /etc/init.d/nagios file and edit line 53 and change it from
to
I did that (replacing nagiosxi by nagios because I have Nagios Core installed) and nagios process is still being killed during reload.
So I changed back again that line from:
NagiosLockDir=/usr/local/nagios/var/subsys
to
As I had problems for starting Nagios 4.2.0 when I upgraded from Nagios 4.1.1 because ndo wasnt updated and it didnt run until I upgraded to ndo 2.1.0 version, I have disabled it temporally and reloading is working without ndo.
In nagios.cfg I have commented out this line:
 broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
This is nagios.log when ndo is enabled in nagios.cfg and I start nagios [1470907868] and later I do a reload [1470907907]. nagios process is killed then.
[1470907868] Nagios 4.2.0 starting... (PID=26381)
[1470907868] Local time is Thu Aug 11 11:31:08 CEST 2016
[1470907868] LOG VERSION: 2.0
[1470907868] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1470907868] qh: core query handler registered
[1470907868] nerd: Channel hostchecks registered successfully
[1470907868] nerd: Channel servicechecks registered successfully
[1470907868] nerd: Channel opathchecks registered successfully
[1470907868] nerd: Fully initialized and ready to rock!
[1470907868] wproc: Successfully registered manager as @wproc with query handler
[1470907868] wproc: Registry request: name=Core Worker 26382;pid=26382
[1470907868] wproc: Registry request: name=Core Worker 26383;pid=26383
[1470907868] wproc: Registry request: name=Core Worker 26385;pid=26385
[1470907868] wproc: Registry request: name=Core Worker 26387;pid=26387
[1470907868] wproc: Registry request: name=Core Worker 26384;pid=26384
[1470907868] wproc: Registry request: name=Core Worker 26386;pid=26386
[1470907868] ndomod: NDOMOD 2.1 (07-28-2016) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
[1470907868] ndomod: Could not open data sink!  I'll keep trying, but some output may get lost...
[1470907868] ndomod registered for process data
[1470907868] ndomod registered for timed event data
[1470907868] ndomod registered for log data'
[1470907868] ndomod registered for system command data'
[1470907868] ndomod registered for event handler data'
[1470907868] ndomod registered for notification data'
[1470907868] ndomod registered for service check data'
[1470907868] ndomod registered for host check data'
[1470907868] ndomod registered for comment data'
[1470907868] ndomod registered for downtime data'
[1470907868] ndomod registered for flapping data'
[1470907868] ndomod registered for program status data'
[1470907868] ndomod registered for host status data'
[1470907868] ndomod registered for service status data'
[1470907868] ndomod registered for adaptive program data'
[1470907868] ndomod registered for adaptive host data'
[1470907868] ndomod registered for adaptive service data'
[1470907868] ndomod registered for external command data'
[1470907868] ndomod registered for aggregated status data'
[1470907868] ndomod registered for retention data'
[1470907868] ndomod registered for contact data'
[1470907868] ndomod registered for contact notification data'
[1470907868] ndomod registered for acknowledgement data'
[1470907868] ndomod registered for state change data'
[1470907868] ndomod registered for contact status data'
[1470907868] ndomod registered for adaptive contact data'
[1470907868] Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
[1470907868] Successfully launched command file worker with pid 26388
[1470907884] ndomod: Still unable to connect to data sink.  1538 items lost, 5000 queued items to flush.
[1470907900] ndomod: Still unable to connect to data sink.  1828 items lost, 5000 queued items to flush.
[1470907907] Caught SIGHUP, restarting...
[1470907907] Event broker module 'NERD' deinitialized successfully.
[1470907907] ndomod: Shutdown complete.
[1470907907] Event broker module '/usr/local/nagios/bin/ndomod.o' deinitialized successfully.
[1470907907] Nagios 4.2.0 starting... (PID=26381)
[1470907907] Local time is Thu Aug 11 11:31:47 CEST 2016
[1470907907] LOG VERSION: 2.0
[1470907907] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1470907907] qh: core query handler registered
[1470907907] nerd: Channel hostchecks registered successfully
[1470907907] nerd: Channel servicechecks registered successfully
[1470907907] nerd: Channel opathchecks registered successfully
[1470907907] nerd: Fully initialized and ready to rock!
[1470907907] wproc: Successfully registered manager as @wproc with query handler
[1470907907] wproc: Registry request: name=Core Worker 26667;pid=26667
[1470907907] wproc: Registry request: name=Core Worker 26668;pid=26668
[1470907907] wproc: Registry request: name=Core Worker 26670;pid=26670
[1470907907] wproc: Registry request: name=Core Worker 26669;pid=26669
[1470907907] wproc: Registry request: name=Core Worker 26671;pid=26671
[1470907907] wproc: Registry request: name=Core Worker 26672;pid=26672
[1470907907] ndomod: NDOMOD 2.1 (07-28-2016) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
[1470907907] ndomod: Could not open data sink!  I'll keep trying, but some output may get lost...
[1470907907] ndomod registered for process data
[1470907907] ndomod registered for timed event data
[1470907907] ndomod registered for log data'
[1470907907] ndomod registered for system command data'
[1470907907] ndomod registered for event handler data'
[1470907907] ndomod registered for notification data'
[1470907907] ndomod registered for service check data'
[1470907907] ndomod registered for host check data'
[1470907907] ndomod registered for comment data'
[1470907907] ndomod registered for downtime data'
[1470907907] ndomod registered for flapping data'
[1470907907] ndomod registered for program status data'
[1470907907] ndomod registered for host status data'
[1470907907] ndomod registered for service status data'
[1470907907] ndomod registered for adaptive program data'
[1470907907] ndomod registered for adaptive host data'
[1470907907] ndomod registered for adaptive service data'
[1470907907] ndomod registered for external command data'
[1470907907] ndomod registered for aggregated status data'
[1470907907] ndomod registered for retention data'
[1470907907] ndomod registered for contact data'
[1470907907] ndomod registered for contact notification data'
[1470907907] ndomod registered for acknowledgement data'
[1470907907] ndomod registered for state change data'
[1470907907] ndomod registered for contact status data'
[1470907907] ndomod registered for adaptive contact data'
[1470907907] Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
[1470907907] Caught SIGSEGV, shutting down...
And this is nagios.log when nod is disabled in nagios.cfg and I start nagios [1470908061] and then I do a reload [1470908106]
[1470908061] nerd: Fully initialized and ready to rock!
[1470908061] wproc: Successfully registered manager as @wproc with query handler
[1470908061] wproc: Registry request: name=Core Worker 26722;pid=26722
[1470908061] wproc: Registry request: name=Core Worker 26723;pid=26723
[1470908061] wproc: Registry request: name=Core Worker 26724;pid=26724
[1470908061] wproc: Registry request: name=Core Worker 26726;pid=26726
[1470908061] wproc: Registry request: name=Core Worker 26725;pid=26725
[1470908061] wproc: Registry request: name=Core Worker 26727;pid=26727
[1470908061] Successfully launched command file worker with pid 26728
[1470908071] SERVICE ALERT: svr_SAE_Valdeolleros_W2012_R2;PING;WARNING;SOFT;1;ECO WARNING - Paquetes perdidos = 0%, RTA = 429.09 ms
[1470908098] wproc: Core Worker 26726: job 3 (pid=26764) timed out. Killing it
[1470908098] wproc: CHECK job 3 from worker Core Worker 26726 timed out after 30.01s
[1470908098] wproc:   host=LIB_CEMCOR_Tomas_Aquino; service=(null);
[1470908098] wproc:   early_timeout=1; exited_ok=0; wait_status=0; error_code=62;
[1470908098] Warning: Check of host 'LIB_CEMCOR_Tomas_Aquino' timed out after 30.01 seconds
[1470908098] HOST ALERT: LIB_CEMCOR_Tomas_Aquino;DOWN;SOFT;1;(Host check timed out after 30.01 seconds)
[1470908098] wproc: Core Worker 26726: job 3 (pid=26764): Dormant child reaped
[1470908105] SERVICE ALERT: svrvm02;WIN-UPDATES;CRITICAL;SOFT;1;CHECK_NRPE: Socket timeout after 30 seconds.
[1470908106] Caught SIGHUP, restarting...
[1470908106] Event broker module 'NERD' deinitialized successfully.
[1470908106] Nagios 4.2.0 starting... (PID=26721)
[1470908106] Local time is Thu Aug 11 11:35:06 CEST 2016
[1470908106] LOG VERSION: 2.0
[1470908106] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1470908106] qh: core query handler registered
[1470908106] nerd: Channel hostchecks registered successfully
[1470908106] nerd: Channel servicechecks registered successfully
[1470908106] nerd: Channel opathchecks registered successfully
[1470908106] nerd: Fully initialized and ready to rock!
[1470908106] wproc: Successfully registered manager as @wproc with query handler
[1470908106] wproc: Registry request: name=Core Worker 27404;pid=27404
[1470908106] wproc: Registry request: name=Core Worker 27406;pid=27406
[1470908106] wproc: Registry request: name=Core Worker 27407;pid=27407
[1470908106] wproc: Registry request: name=Core Worker 27403;pid=27403
[1470908106] wproc: Registry request: name=Core Worker 27405;pid=27405
[1470908106] wproc: Registry request: name=Core Worker 27408;pid=27408
[1470908131] SERVICE ALERT: svr_SAE_Valdeolleros_W2012_R2;PING;WARNING;SOFT;2;ECO WARNING - Paquetes perdidos = 0%, RTA = 525.68 ms
So I think it's something involving ndo module and/or daemon
