Good afternoon friends,
I wanted to know if it is possible I define the vision of a comun user Nagios, to see only a few servers, and not all.
For example: There are 50 servers, however I want my client to the user of it, see it only servers that exist it.
It's possible?
ACL applied to Nagios User
Re: ACL applied to Nagios User
Yes that can be done, you can setup a user to only see the hosts and services that are assigned to them. That is called Multi Tenancy and the link below describes how to set that up.
https://assets.nagios.com/downloads/nag ... enancy.pdf
ednaldojta
Thank you friends!
We can close this post as solved.
