Nagios Notifications Disablement for One Particular Service
sudharzit
Post by sudharzit »
Hi Team,
I would like to know some possibilities in nagios that can be feasible to implement or not. For an instance if I want to permanently disable the one of the service in the service definition itself by using the directive notification_enabled=0. It was disabled temporarily not permanently. If I try to initiate the external command against the hostgroup , the particular services which I have disabled in the configs are enabled based on the external command issued. I want the solution that the service should not be enabled even though external command is issued. Do you know how we can implement it? If possible respond to my query. Thanks in advance!!
Regards
Sudharsan
Re: Nagios Notifications Disablement for One Particular Serv
It should just be notifications_enabled 0 on the service that you want to disable notifications for. Can you show us the complete service definition?
Can you show us a screenshot of what you're experiencing? I'm not sure what would be changing this. Does anything appear in /usr/local/nagios/var/nagios.log? Can you attach it for us to review?
sudharzit
Post by sudharzit »
Please find the service definition for the services which we disabled the notification permanently on the configs. But if the NOC team handles the enable or disable monitoring ticket, they try to enable/disable the services using the GUI. Even though we have set the configuration with notification_enabled = 0 , if you try to enable the service using the GUI. it will send the external command to enable the notification for the services. likewise if you tires do for the host group also the disabled services associated with the hostgroup will be enabled with notification.
# Service 'Vod Platform Status'
use active-services
hostgroup_name xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
service_description Vod Platform Status
check_command check_by_ssh!"/usr/local/ccdn/nrpe/check_vod_status.sh"
servicegroups xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
#contact_groups support
action_url https://XXXXXXXXXXXXXXXXXXXXXXXX/XXXXXXXXXXXXXXXXX
_SERVICEOWNER XXXXXXXXXXXXXXXXXXXXX
_SEV 4
Log :
if i try to disable the service in service level
[1424463832] EXTERNAL COMMAND: ENABLE_SVC_NOTIFICATIONS;host_namexxxx;Vod Platform Status
if i try to disable the hostgroup associated services
[1424463832] EXTERNAL COMMAND: ENABLE_HOSTGROUP_SVC_NOTIFICATIONS;hostgroupnamexxxx
Sudharsan
bwallace
Post by bwallace »
Have you considered restricting access for the NOC team so they can only view specific hosts/services? You could also configure Nagios so they cannot issue cmds from the UI for a specific host/service. This would be a good starting point:
https://assets.nagios.com/downloads/nag ... iauth.html
sudharzit
Post by sudharzit »
Yeah that's great idea. But in our scenario, NOC should have full access to the execute the external commands because they are the major ticket executor of monitoring tasks. We can't restrict but we need to find a solution how we can overcome this issue. Service shouldn't override if we execute the external command. If we turned off the notifications on service definition level how it was enabled using external commands.
If the NOC group needs full Admin rights to the Nagios server, then there is no way to remove the ability for the NOC group to change specific settings for one service.
sudharzit
Post by sudharzit »
Can anyone help me how set up the restriction to execute the external commands for the specific services.
Sudharsan
Post by Box293 »
Nagios does not allow that granular level of control.
All you can do is enable / disable that privilege (globally) for specific users.
