How do you use the --skip-broken option with ./fullinstall
kellyangell
Post by kellyangell »
Trying to run the ./fullinstall of nagiosxi on RHEL 7 , but there are packages that aren't installed that i can't download using yum. it says there is an option to skip these broken packages using --skip-broken , but it doesnt work. does anyone have a clue how to skip these dependencies ?
Re: How do you use the --skip-broken option with ./fullinsta
You need these packages in order to install XI. Is there a specific reason you cannot download the needed packages?
The installer should create an install.log file for us to look at, so we can see what the underlying issue is. Can you post this?
