our enivroment is configured to not re-send notifications at all, so 0 minutes in the re-send field of wizards.
It's what has been agreed, and is ok.
But now I would like to create a "reminder" which would do one of the following things:
- Generate and send out a report with all open problems (so Warning, Critical, Unknown state of Hosts and Services)
The report should be user based, so each user would get all the hosts/services he is monitoring (monitoring contact based?). - or re-send notifications for all open problems.
The Notifications Legacy Report looks kinda what I would like, but there are no selectable periods and the Notification detail "custom" level I have no idea where to check. Is there a way to maually build a report?
I don't know which solution would be better, so it would be the best if I could test both, and no, setting an re-send on each host/service for 10080 minutes (1 week) is not a good idea
